feul pump wiring
Flow
I am sorry Flow, I checked all my FSMs close to your year (84,85,86) and the all say there is a black wire (to ground) and a light green with red tracer wire from the rev sensor.
I'm sorry, hopefully someone else has a manual with your colors.
Shameless bump none the less.
I have my harness apart and am wiring the buggy with it.
On mine the ground wire is black with some brown rings.
Try following both wires to the main harness. Once at the main harness one of them should be coupled to another wire of the same color. These wires should couple with others of the same, they ground to the chassis.
Good luck,
Glenn,
82 Hatch, just wired the fuel pump.
01 Forester, factory wired fuel pump.
