Wirebrush Posted February 7, 2009 Share Posted February 7, 2009 Cooper Discoverer 195 R15. I have been looking for a 27" skinny off road tire for my Brat when I get the lift done and I came across some barely used Coopers and I was thrilled to find that they measure 27 inches in diameter and they are narrower that anything else I've found in a 27" tire. Quote Link to comment Share on other sites More sharing options...
TeamCF Posted February 7, 2009 Share Posted February 7, 2009 They make a 14" all terrain as well all the way down to a 26" (and up) I was gonna pick up a set as they are the same size as the street tires I have on now (195/75/14) But the $$$, Swampers are cheaper and more agressive. At least new. You found used. if they are in good shape and gotten for a deal, then good score. http://www.coopertire.com/html/tireselector_bySize.aspx?twtd=195&artw=75&rd=14 (The Discoverer Radial LT) Quote Link to comment Share on other sites More sharing options...
Wirebrush Posted February 7, 2009 Author Share Posted February 7, 2009 Is $175 for a set of four with less than 100 miles on them a good deal? Quote Link to comment Share on other sites More sharing options...
michael appel Posted February 7, 2009 Share Posted February 7, 2009 ground hawg makes a 27 inch mud tire to $$$ is the thing also found quite a bit more to but $$$ wise swampers are the better deal Quote Link to comment Share on other sites More sharing options...
Greenley Posted February 7, 2009 Share Posted February 7, 2009 (edited) I got a set of 27" Kumho MUD-terrains w/50 miles mounted on pretty 14" wheels for $300 delivered :-p Too bad they discontinued these, because they're unstoppable in slop. A/T tires will prove to be nearly worthless in less than ideal conditions offroad. Though, the Low Range of the BRAT will make you think otherwise, if you're new to dual range Subarus. Edited February 7, 2009 by Greenley Quote Link to comment Share on other sites More sharing options...
TeamCF Posted February 7, 2009 Share Posted February 7, 2009 Is $175 for a set of four with less than 100 miles on them a good deal? I would say thats a very good deal. By the time it's mounted and balanced that would pretty much cover only one new one. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted February 10, 2009 Share Posted February 10, 2009 ground hawg makes a 27 inch mud tire to $$$ is the thing also found quite a bit more to but $$$ wise swampers are the better deal ughhh.... swampers are just so obnoxious to drive on pavement, kill milage, and wear out after I dunno, like 5000 miles? Quote Link to comment Share on other sites More sharing options...
MSSLGECKO Posted February 12, 2009 Share Posted February 12, 2009 Cooper Discoverer 195 R15. I have been looking for a 27" skinny off road tire for my Brat when I get the lift done and I came across some barely used Coopers and I was thrilled to find that they measure 27 inches in diameter and they are narrower that anything else I've found in a 27" tire. I had these same tires (R14) on my '83 lifted (4/3 BYB) wagon. They were great! I did have to trim the fenders a tiny bit to prevent rubbing. The car lived in Missoula and Bozeman and now live w/ its new owner in Kalispell. Quote Link to comment Share on other sites More sharing options...
