Help remove stubborn oil pump
6 replies to this topic
#1 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 07 February 2009 - 12:23 PM
I can wiggle it, but it won't come out. It is wiggling between the base plate and main body of the pump. If the base plate stays on how do I get that unstuck? Any tips? It's a 77 ea71, engine is in the car.
P.S. HTKYSA says tap it each side with a mallet. Done that.
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,108 posts
  • East Coast
Posted 07 February 2009 - 04:47 PM
make sure you got all the bolts out. (i've done that before)
#3 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 07 February 2009 - 07:43 PM
all four bolts are out. Anyone got a trick?
#4 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 07 February 2009 - 10:56 PM
when I had one that wiggled like that, the base plate had already broken... so I kept smacking it until the main part came out, then I used a sturdy screw driver to pry twist out the remains... took a long time, and obviously wasted the pump... and had to clean out the area good of any small chunks :)
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 07 February 2009 - 11:57 PM
loosen the frontmost bolt for the crankcase halves, just above the oil pump:banana:
#6 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 08 February 2009 - 12:00 AM
Put the oil filter back on and use it to lever back and forth. Chances are the pump is cracked between the layers already.
#7 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 08 February 2009 - 01:41 AM
Thanks for the advice, Here's what worked for me and It's simple enough, I put a punch on the base plate from under the car. Once the base plate came loose, the pump came out without much fuss, And I think the pump can be salvaged. The reason the pump needed to be replaced is because it was leaking badly between the body of the pump and the plate. the two pieces are held together by two screws, which had worked quite loose. It looks like I can replace a couple o-rings and put it back together. For a replacement pump, I tried to remove the pumps from two other engines I have and they both had the same issue. I have one more to try tomorrow and if that one is the same, I will have to just try to refurbish one and go with it. Oh boy.....
Since this would seem to be an issue with the ea71 pump, would it be a good idea to use a little locktight on the screws that join the pump to the plate?
Unfortunately ea81 pumps won't fit a ea71.
