have a 94 impreza and notice a slight gear noise coming from the engine at idle but goes away when reved. should i be worried about this...
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
engine noise
Started by
hebrewhammer
, Feb 10 2009 02:12 PM
6 replies to this topic
#1
Posted 10 February 2009 - 02:12 PM
#2
Posted 10 February 2009 - 05:50 PM
How many miles?
Spray the acc drive belt with some water and see if the noise goes away. if it does it can be the alt/ps/idler on that belt.
When was the last time the timing belt was done and what was changed with it?
nipper
nipper
#3
Posted 11 February 2009 - 10:57 PM
150k on the car.
not sure on the timing belt. but going to change it this weekend.
sounds a bit different on the left side head than the right in terms of clicking.
Going to adjust the valves this weekend also.
#4
Posted 11 February 2009 - 11:02 PM
If its unknown, then your going to do the entire timing beltthing:
water pump
cam seals
main seal
idler
tensioner
re-seal the oil pump.
Its quite possible what your hearing may be a tensioner/idler giving up the ghost. Dont drive the car till you get to inspect those parts. If they let go then can do lots of engine damage.
nipper
water pump
cam seals
main seal
idler
tensioner
nipper
#5
Posted 11 February 2009 - 11:07 PM
Track the noise down a bit, front of engine, back, trans, sides? Should be able to narrow it down for sure.
Any difference in gear or out of gear?
Ebay has timing belt kits for only $80. Includes the belt and all new pulleys and tensioner. By this time I would guess most, if not all, of your pulleys need replaced anyway.
#6
Posted 12 February 2009 - 02:02 AM
Now i am hearing a very faint higher pitched screal.
not driving the car till i figure it out.
I can only hear it when i'm driving/ sitting in the the car. when i listen in the engine bay i can't hear it.
Can hear in gear and out of gear, speeds up as rpms climb.
Edited by hebrewhammer, 12 February 2009 - 02:07 AM.
#7
Posted 12 February 2009 - 10:04 AM
can also be a failing water pump. Take off those timing belt covers and inspect it.
nipper
nipper
