Trans took a barf 81 subi look at the pics
So my dad was drinving my 81 wagon (4wd d/r manual) and came home said it wouldn't go into 3rd gear. Checked the Dipstick, no oil just smoke film. Drained less than a qt out of it. Found 4 or so teeth from I think 3rd gear in the bottom of the trans, with my finger.
I am thinking junk yard trans, or rebuild. Let me know if anyone has experiance with rebuilding a subi trans. The crazy mechanic inside of me says go for it. But I am curious on expence
To see the photos follow the link then click on "My Photos"
http://photos.yahoo.com/subi81@sbcglobal.net
Thanks a bunch!
Oh, man...you just missed half price weekend at Pick-N-Pull. I believe trannys were something like $65~75, maybe less.
If I remember correctly, 3rd gear problems are considered common in the EA81's. Probably still a bargain to get a used one, anything's better than what you have now.
If you go that route, I believe PnP charges a core for the unit. Just so you're prepared.
you don't want to rebuild it yourself, it's a nighmare, did it once with a VW, something I never want to do again. You'd need special tools, help (at least one other set of hands) and a BIG press or vice...
my zwei pfennig,
-Dok
Typical gear teeth - that one's toast.
Rebuilding the 4 speed is about the worst possible request a Subaru mechanic could get as far as tranny work goes. The innards of it are a real nightmare. Special tools are required just to dissasemble it, and the amount of things that can go wrong durring inspection / repair / assembly are just mind boggling. I have a rebuild manual sitting here, and have been looking into this possibility myself - but I'm crazy. If you value your sanity, get one from the JY, and be done with it. Better yet - put in a 5 speed 4WD from an EA82 car and call it good.
I'm a pretty darn good mechanic, and I wouldn'y put my chances of rebuilding one of these at more than say 20%. By the manual, and the research I've done I would have to say it might be the most challenging thing I will have yet attempted.....
heh. i've also pulled parts off of a car i once owned at the yard. i usually strip them down pretty well first but sometimes ya gotta go back :P
i say swap in a 5 speed d/r as well. i don't know if you'd need the rear differential to match.. if your car already has a 3.9 ratio rear differential you'll be ok there.
