Guest bill rigsby Posted June 25, 2003 Share Posted June 25, 2003 What is the correct procedure with the gasket sealer on the oil pump since there is no true gasket? Apply to one or both surfaces, assemble wet, tacky, or dry? I don't want any leaks! I was surprised there was no gasket, I have never been a fan of silicone sealers but that is what Liberty said was used so I ordered it. Bill Quote Link to comment Share on other sites More sharing options...
Guest jibber Posted June 29, 2003 Share Posted June 29, 2003 use grey rtv it works pretty much only on aluminum and quite well. follow the directions on the tube and you'll be a set. Quote Link to comment Share on other sites More sharing options...
Guest Subaru Maker Posted June 29, 2003 Share Posted June 29, 2003 I do not know what model you have, but on the current model 2.5 that we build, we use a lint free cloth covered sponge to wet the pump surface before we apply the sealer. The sealer is made by Three-Bond. Quote Link to comment Share on other sites More sharing options...
