Chunky Steering
3 replies to this topic
#1 Chip
    USMB is life!
  • 162 posts
  • Canada
Posted 16 January 2004 - 10:58 AM
My steering has become kind of stiff. It'll turn smoothly for about 1/2 turn then it hits a stiff spot...if I keep turning the wheel in the same direction it'll hit another stiff spot. It does it in both directions.
If it wasn't -30°C right now I'd crawl underneath and take a look at it......any ideas ?
#2 meep
    USMB Regular
  • PipPipPip
  • 79 posts
  • No. AL
Posted 16 January 2004 - 02:03 PM
Don't think I'd worry, especially at those temps: metal shrinks, things are tight and the oil is thick.
You might consider draining fluid and replacing with full synthetic dexron III ATF. Less stiction with this fluid may be a great benefit at these low temps.
#3 cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 16 January 2004 - 02:07 PM
knock the ice out from under the fenders.
#4 Chip
    USMB is life!
  • 162 posts
  • Canada
Posted 26 January 2004 - 08:46 AM
It turns out it was the U-Joint on the steering column. A bit of WD-40 and everything's cool.
