Worn Starter Contacts?
5 replies to this topic
#1 biggunsnu
biggunsnu
    New User
  • Pip
  • 2 posts
  • Auburn
Posted 15 March 2009 - 11:37 AM
Recently changed out the EJ25 engine in my 1997 Subaru Legacy Outback with a Japanese equivalent, everything works great but for the fact that after the initial start once you reach your destination it will not start again, not even engaging the starter. I am thinking it's a bad starter but was wondering if anyone has any other ideas. The starter is receiving appr. 12V
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 5,634 posts
  • Virginia
Posted 15 March 2009 - 12:27 PM
you need to rule out the ignition wiring. next time it happens hot wire it from the positive battery post to the small tab connector on the solenoid of the starter, not the big heavy guage one. if it fires then the problem is not the starter contacts. if it doesn't then it's the starter.
but new contacts may correct it even with the wiring being less than perfect / original. less juice / amps from the ignition wiring and old contacts combined, may be the problem, correct either and it may be fixed.
contacts are pretty easy, but i chose to install a relay, really easy.
#3 Olnick
Olnick
    Ol' Subaru Guy
  • 2,367 posts
  • Honolulu HI
Posted 15 March 2009 - 12:30 PM
. . . not even engaging the starter.
Sounds like the solenoid may be bad. Might want to remove the starter (it's easy, one bolt and one nut--at least that's how it was on my EJ22) to check the solenoid's plunger action and condition of the contacts. If it's just the contacts that's a cheap and easy fix.
Or if you have to, replace starter and/or solenoid with a reconditioned one. Personally I would avoid a chain store rebuilt starter. Check around for an auto-electric shop locally--ask local mechanics who they use.
Good luck.
#4 Gloyale
Gloyale
    It's a sickness
  • 7,085 posts
  • Corvallis, OR PNW
Posted 15 March 2009 - 01:54 PM
Legacy already uses a relay.
All the issues I've seen in newer gen are from blackened, carbon scored contacts in the starter.
#5 johnceggleston
johnceggleston
  • 5,634 posts
  • Virginia
Posted 15 March 2009 - 04:43 PM
you're right, as usual, but adding a relay at the starter to my 97 obw, eliminated my no start problems.
#6 biggunsnu
biggunsnu
    New User
  • Pip
  • 2 posts
  • Auburn
Posted 18 March 2009 - 04:51 PM
Thanks for the advice everyone, tried jumping the wiring like you suggested with no luck. Now onto starter removal and replacement with fingers crossed.
