fuel line 3/8 ?
16 replies to this topic
#1 Dave643
Dave643
    USMB Regular
  • PipPipPip
  • 56 posts
  • colorado springs
Posted 29 March 2009 - 04:35 PM
Greetings,
Replacing the fuel filter in my '92 Legacy. I also want to replace the rubber fuel lines. What size hose is it? My local parts store said 3/8" but it seems a little to big? I certainly don't want any leaks.
#2 subaru360
subaru360
    has no catchy title
  • 1,282 posts
  • Fleetwood, PA
Posted 29 March 2009 - 06:20 PM
I use 5/16, be sure to get the high presure fuel injection hose.
#3 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 30 March 2009 - 02:33 PM
3/8" will be a little bit too big. 1/4" will be a little bit too small. 5/16" will work just about right without having to get some metric diameter hose.
Right on, it must be bonafide fuel injection hose. Ordinary 'fuel hose' is not acceptable.
We want to avoid this scenario:
Posted Image
#4 Dave643
Dave643
    USMB Regular
  • PipPipPip
  • 56 posts
  • colorado springs
Posted 30 March 2009 - 03:39 PM
Yep, I went back to the parts store and got 5/16. And I did use fuel injection hoses....That stuff is expensive!
#5 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 29 April 2010 - 06:33 PM
I'm going to replace all the rubber fuel lines on my 1991 Legacy SS. The only fuel injection hose I've found so far is 5/16", which is 7.9375 mm. Now, I can get metric fuel injection hose at Discount Import Parts, but they only stock 7mm and 9mm, no 8mm.
Three questions:
1. Is the stock hose 8mm?
2. If so, where do I find some?
3. Should I just get the 5/16" hose, and not waste my time hunting down 8mm?
#6 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 29 April 2010 - 06:54 PM
how big is .0625 mm? will 5/16 hose stretch that much??
my guess is that you can try it and see faster than you can do the math.
edit:
it's about 1/400 of an inch, or 0.7 % of the 5/16 (hose less than 1%).
Edited by johnceggleston, 29 April 2010 - 07:08 PM.
#7 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 29 April 2010 - 07:12 PM
Still two questions left...
I'd go and buy a couple feet of 5/16" F.I hose, and try it, but most auto parts stores don't like taking returns on hoses that have been cut to length.
#8 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 29 April 2010 - 07:21 PM
5/16" inch is the way to go imho. It will stretch that much no problem, at least for me. I have used 5/16" fuel injection hose on several soobs. 3/8" will work, but it is a little bit too big and requires clamping the heck out of it to make it not drip. I've been buying the FI hose in 25 foot spools on eBay. It was a name brand, I forget now, a brand I have seen in parts stores. But at much less than the parts store price.
#9 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,988 posts
  • Portland
Posted 29 April 2010 - 10:09 PM
Go to A1-Coupling over in Tualitin. You want 5/16" high pressure fuel rated hose. It's like $2 a foot or less from them vs. $8 to $10 a foot from auto parts stores.
You can't buy metric hose in the US that I know of except for some select sizes through places like Discount Import Parts, etc. They have some german hose in bulk that is used on the VW's for breather lines and vacuum lines, etc. I wouldn't use it for the FI line though - I always use 5/16" hose from A1 - it's close enough for the 8mm stuff and their hose is rated to something rediculous like 1800 psi. :rolleyes:
And yes - when you are talking about rubber hose - 5/16" and 8mm are the same thing. They are even the same when talking about tubing and tubing fittings really. So close that it's not even worth worring about..... maybe if you were working for NASA. 1/4" and 6mm are NOT interchangeable when talking about tubing but generally ARE when talking about hose..... just to give you an idea..... .25" = 6.35mm.
Edited by GeneralDisorder, 29 April 2010 - 10:16 PM.
#10 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 29 April 2010 - 10:34 PM
Thanks. I'm guessing the brand on eBay is Gates, which is what I'm finding at most part stores.
Excellent, thank you. The $8 -$10 a foot cost is why I was asking. $2 a foot sounds worth the drive there.
All my searches for 8mm hose pulled up Australian and British racing supply sites. 1800 psi should do it, I like overkill!
Good to know. I tend to get hung up on details like this. I like to think I am being thorough, when in reality I am just thoroughly wasting time. :rolleyes:
#11 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 30 April 2010 - 12:27 AM
Why not go to the dealership and just get oem. Either way does the fuel hose really deteriorate? Is it really necessary to replace?
#12 GeneralDisorder
GeneralDisorder
  • 20,988 posts
  • Portland
Posted 30 April 2010 - 01:58 AM
The dealer does not carry bulk fuel line. You would have to order the exact part number for the specific hose. I recently asked my local dealer about this in fact. Other dealers may be different but the same scenario applies with dealerships as with auto-parts stores. The price is going to be rediculous when down the street at the hose and coupleing industrial supply you can get hose that is impervious to just about everything, has a working temp of 250*F, and a pressure rating of 1800 psi for a little over a buck a foot. Why would I bother with the dealer?
As to why you would need some - engine swaps mostly for me. Sometimes the lines are damaged when replacing fuel filters, etc as well. Though I've developed a technique that rarely results in damage on these lines - I've done a lot of them though and trial and error has resulted in damage in the past.
#13 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 30 April 2010 - 12:36 PM
My fuel hoses have checking/cracking at the ends, and I'm replacing the fuel filter, so why not just replace the fuel lines just to be safe? They are 20 years old.
I went to Oil Filter Service Co. in SE Portland this morning, and asked for some 5/16" hose suitable for fuel injection. They sold me some Gates LOL Plus. After getting home, I checked the Gates website and found that this hose is not recommended by Gates for use with gasoline. :mad: I love driving around in circles. :rolleyes:
#14 GeneralDisorder
GeneralDisorder
  • 20,988 posts
  • Portland
Posted 30 April 2010 - 01:13 PM
Never heard of that place, but sounds like they have no clue about their products. A1 is an industrial supply house - they know their products and they make custom hoses all the time for all kinds of things - you can have custom brake lines made in any style and length - and they can do it while you wait. When I worked for a local machinery manufacturer the A1 rep would come by and pickup the hoses we needed replaced and have new one's to us the same day.
#15 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 30 April 2010 - 02:26 PM
It looks like I will be making the trip to A1. I had heard good things about Oil Filter Service Co., and they are close by, so I decided I would give them a shot. When I went to return the hose, I explained to guy that Gates does not recommend the LOL Plus for gas or diesel. His response was, "Well, we sell a ton of this stuff for fuel. Do you need it to say fuel injection on the hose?" I responded "No, I just need something that is actually approved for use with gasoline by the manufacturer." He got pissed off, and said "I'll just make this easy, and give you your money back." While he was in the back, another employee looked up the hose in question, and told me that although the Gates LOL Plus meets the same PSI, abrasion, and heat requirements, it is not recommended to use as fuel line, but he couldn't find a reason why. The other guy came out from the back, and couldn't even look me in the eye as he handed my money back.
What a way to do business.
#16 GeneralDisorder
GeneralDisorder
  • 20,988 posts
  • Portland
Posted 30 April 2010 - 02:48 PM
They might carry the same stuff at A1 - I'm not entirely sure. I was told it is perfectly safe for gasoline and I've used it for that and never had a problem. Looking at the gates web site it does say "do not use unless approved by their H/C division". Which, if you read between the lines, means that some applications involveing gasoling and diesel are, or have been, approved for use with that hose.
Ultimately the stuff is capable of 300 psi and ought to handle the ~50 psi of the EJ22T's pump without any trouble at all.
It's a nitrile based hose - so it's basically completely impervious to gasoline if that's the case.
I would run it - all day and twice on Sunday's. But I've done it before (apparently without knowing this Gates reccomendation business :rolleyes:), and I also know a bit about rubber and seal technology and what is acceptable with regards to nitrile (buna-n), and viton, silicone, polyurethane, neoprene, teflon, etc and the fluids they can withstand.
When I worked for RMC I had occasion to buy a lot of this stuff from A1 and used it for diesel and gasoline applications for generators, etc. Never had a single problem with it. Experience would sugest that it will do the job. I probably have some that I've used on FI conversions and such as well.
Edited by GeneralDisorder, 30 April 2010 - 02:52 PM.
#17 2.5_IMP
2.5_IMP
    USMB is life!
  • 149 posts
  • CP, MD
Posted 30 April 2010 - 04:27 PM
From your experience, it sounds like the Gates LOL Plus would be perfect for fuel line. According to this http://www.gates.com...chemical_04.pdf , NBR has excellent resistance to gasoline. So, why doesn't Gates market it as fuel line? My guess is that it isn't DOT approved, and the process to get it approved is costly.
I know less than nothing about almost everything, so when I returned the hose to Oil Filter Service Co., I was hoping they could offer me an explanation as to why they sell it as fuel line. If they had given me the informed, logical explanation you had, I would have walked out of there with the line, and installed it on my car without a second thought.
"Not recommended for gasoline or diesel fuels."
http://www.jgbhose.c...?prod_id=600270
I am tempted to call and ask why, but I think I've wasted enough time today.
