Help! My Subaru wont start
29 replies to this topic
#26 pearson801
pearson801
    New User
  • PipPip
  • 17 posts
Posted 04 April 2009 - 07:13 PM
Thanks to everyone again who has helped so far here is a update. I attached a switch to the negative terminal of my battery and the other end to the spade of the solenoid therefore bypassing the ignition switch and the inhibitor. when I push the button I can hear the plunger move every time one out of like 20 times it would turn over. Very frustrated I went to disconnect from the spade and my solenoid is very very hot. Question is, Should it get that hot? and Any other ideas?:confused:
#27 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 04 April 2009 - 08:36 PM
If I am reading your last post correctly you are grounding out the ignition lead to the starter solenoid. That lead is supposed to have 12 volts on it to run the solenoid not a ground connection. You are shorting the circuit when go to start the mode and so yes it will get hot. I am surprised you didn't blow a fuse.
If you can apply 12 volts to the solenoid and make the starter run then the starter and the solenoid are ok. The problem is somewhere in the circuit wiring that connects to the solenoid. Gloyle stated that this kind of trouble is mostly due to the relay which may be under the dash. I highly recommend you go to the Subaru web site and purchase the data you need to help you fix this.
Edited by Cougar, 04 April 2009 - 08:41 PM.
#28 pearson801
pearson801
    New User
  • PipPip
  • 17 posts
Posted 05 April 2009 - 01:36 PM
but like i had said before it only works maybe one out of 20 times and I bypassed the ignition switch all together I mean yeah I guess that makes since that is why it is hot but your saying there should be a relay under the dash?
#29 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 05 April 2009 - 04:13 PM
I am just assuming the relay that Gloyale mentioned is under the dash somewhere, I don't know that for sure. The service data will show you where it is.
The problem you are having is due to an intermittent connection that appears to be somewhere before the starter solenoid. Like I said before, if you can make the solenoid work by applying 12 volts to the solenoid contact that is normally tied to the ignition switch then the solenoid is ok and the trouble is before that point.
#30 pearson801
pearson801
    New User
  • PipPip
  • 17 posts
Posted 05 April 2009 - 06:04 PM
well i have the 93-96 supplement manual and I am still not finding this relay so if anyone know where this realy might be then let me know
