'92 Loyale instrument cluster light not working
9 replies to this topic
#1 koovle
koovle
    New User
  • Pip
  • 3 posts
Posted 09 April 2009 - 09:51 AM
Hi, this is my first post. I recently got a '92 five speed 4WD loyale and have been giving it the work over. It's running like a dream and I love it, however the instrument cluster lights are not working. The stereo has been ripped out of the dashboard and the clock will come on and off, sometimes really bright, sometimes dim, sometimes not working at all. I would apprieciate any suggestions or help with these problems. :)
The rear wiper isn't working either . . . ;)
Edited by koovle, 09 April 2009 - 09:57 AM.
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 09 April 2009 - 10:07 AM
Welcome to the forum.
I assume you have checked all the fuses under the dash already. I would check to see if the dimmer control is getting voltage next.
#3 koovle
koovle
    New User
  • Pip
  • 3 posts
Posted 09 April 2009 - 10:33 AM
All the fuses look good and will check the dimmer control voltage next.
#4 azsubaru
azsubaru
    Subaru Fanatic!
  • 452 posts
  • Phoenix, AZ
Posted 09 April 2009 - 11:03 AM
RE: Clock problems: Those clocks often have a cold solder joint on the circuit board that causes problems like that. You can usually repair it easily with a solder gun. It's by a resister that gets really hot, not hard to find.
#5 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 09 April 2009 - 11:39 AM
Does you heat defrost fan work on all 4 speeds by any chance. these are very common problems on all ea82 Subaru's
#6 koovle
koovle
    New User
  • Pip
  • 3 posts
Posted 09 April 2009 - 12:39 PM
Uh, the heater works in all the fan speeds and positions, the rear defrost works as well . . .
should I remove the instrument panel or is there a work around?
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 09 April 2009 - 09:45 PM
take a look at the dimmer swithc. there are 2 cases that i can account for where the dimmer switch burned out
#8 Gloyale
Gloyale
    It's a sickness
  • 10,622 posts
  • Corvallis, OR PNW
Posted 09 April 2009 - 09:54 PM
+1 on that. Dimmer switch is ussually the culprit if they ALL go out.
#9 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 10 April 2009 - 03:40 AM
...the instrument cluster lights are not working. ...
Have you Checked if one of the Headlamps is Dim too? ... if So, your Subie Must have a Bad Relay.
One of the Two Headlamps` Relays Control the Dashboard Lights Too, the other Relay Controls the Blue "High Beams" Light at the Dash too.
#10 Gloyale
Gloyale
    It's a sickness
  • 10,622 posts
  • Corvallis, OR PNW
Posted 10 April 2009 - 10:39 AM
A blown fuse will cause the dim headlight as well.
but the relay IS a very good place to check.
My money is still on the dimmer switch.
