what is it?
3 replies to this topic
#1 Guest_1 Lucky Texan_*
  • Guests
Posted 23 June 2003 - 06:31 PM
I have an '03 OBW H6 3.0 . There is a small plunger/spring-loaded cover dealie to the upper right of the gear shifting 'gate' area. What is it? Some kind of bayonet mount for something? Some kinda' trannie control button?
Carl
1 Lucky Texan
#2 Guest_Commuter_*
Guest_Commuter_*
  • Guests
Posted 23 June 2003 - 08:25 PM
I don't know the inside of these cars.. but there is usually a spot to shove your key in in case one needs to override the shift interlock. Perhaps that is it? Location sounds about right.
Or... If you have a VDC, there is a defeat switch somewhere...
I'm sure someone will know. Check the manual!
Commuter
#3 Guest_1 Lucky Texan_*
  • Guests
Posted 24 June 2003 - 09:44 PM
Um - actually I was wrong about the 'spring loaded part - that was on a different vehicle we were test driving before we settled on the OBW. Still, this car has a small friction fit cover in the place described. Probably is some kinda' override thingy - will look in manual soon.
thanx
Carl
1 Lucky Texan
#4 Guest_1 Lucky Texan_*
  • Guests
Posted 26 June 2003 - 09:38 PM
Yeah - shifter lock override - but you use a screwdriver to push down on a release - looks like a key may not be long enough.
its in the manual - DUH! - I finally looked - though the index is crappy - you kinda have to flip around a lot to find stuff.
Carl
1 Lucky Texan
