more axle problems
14 replies to this topic
#1 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 21 April 2009 - 09:46 PM
so i've gotten one aftermarket and 2 junkyard axles and all have ground and clicked right from the get-go. My next step is a MWE or Subaru. Is there anything like engine position, alignment, or anything random that could cause a weird drive angle?
when turning right or hitting bumps the left axle makes noises.
thinks its the CV or the DOJ joint that has failed?
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,731 posts
  • East Coast
Posted 22 April 2009 - 06:59 AM
that's really bizarre. 1 aftermarket and 2 junk yard, you have bad luck or are damaging them somehow. i can't think of anything that would cause problems, they are capable of quite a bit of movement.
i've used tons of junk yard axles with great results (because they are Subaru axles, at least the ones I've bought).
you can swap sides (left to right) and see if the clicking moves just to make sure it is the axle.
#3 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 22 April 2009 - 11:23 AM
what car?
#4 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 22 April 2009 - 11:25 AM
There are reasons cars are in junkyards, and we all know the tales of bad aftermarket axles.
Sometimes it pays just to buy the new part and be done with it.
As long as you dont have any frame rust and the wheel bearing is good there is no reason for the car to cause the axle failures.
nipper
#5 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 22 April 2009 - 06:41 PM
95 impreza awd.
#6 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 22 April 2009 - 08:51 PM
i switched the axles the sound did not migrate.
It only grinds when i'm going straightish/right and turning right and only on the drivers side.
looking at my engine/trans orientation it appears that the axles are skewed a little to the right if looking out the front windshield. The drivers side is skewed forward a bit and the passenger is skewed back. I would say it is less than 10 degrees. Is there a way to adjust the angle of the drivetrain. I loosened the engine mount bolts and drove around to see if the engine would settle in a natural position. The grinding worsened and would appear in almost any turn to a degree. I am 98% positive this is still an axle issue because evertime i get a replacement they grind right away but still not as bad as the one i replaced. Going to Order two MWE Axles to atleast have constant in this process.
Any help would be appreciated. it sucks so bad having a car that works in every aspect except for damn CV axle!
wish i had Selectable 4wd so i could just click it into 4wd and drive on the rear!
#7 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 22 April 2009 - 08:55 PM
Im wondering if you have the beginings of wheel bearing failure. You really cant eye up driveline alingment well, you need to use a ruler of some kind and fixed points, like the drive belts vs the front bulkhead/radiator. Have you removed the rotors to check them front and back. Have you checked the brake pads and backing plates??
nipper
#8 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 22 April 2009 - 09:11 PM
new rotors. Everything spins good. Only grinding when load is on the axles. If i put it in nuetral and turn sharp still makes some noise but not as much as when the axles are loaded up with torque.
i have a pretty good eye but i can still be worng. I can see the axle coming out of the doj and one side is skewed more than the other. My logic says if all is true then it should be coming straiht out, or both should be skewed the same angle and direct.
With wheel bearing failure why would it only make those noise only one direction? ackward-uneven forces on the worn out bearing?
Also, this car was in an accident with the last owner, front left sidepanel. crushed in the front a tiny bit.
could my frame be bent. cruises down the road straight as an arrow. i highly doubt it but i'm just throwing it out there.
keep them ideas coming!
Edited by hebrewhammer, 22 April 2009 - 09:13 PM.
#9 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 22 April 2009 - 09:12 PM
it may make it in reverse but your not going fast enough to hear it.
nipper
#10 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 22 April 2009 - 09:14 PM
by one direction i mean left or right. Makes noises bothe forward and reverse.
#11 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 22 April 2009 - 09:19 PM
im going wwith a wheel bearing.
wheel bearings will do that untill they get really bad and the only thing holding the wheel hub on is the axle nut.
AHA!
Have you got a stethascope around or a wooden dowel. use that to listen to the bearing via the knuckle.
nipper
#12 john in KY
john in KY
    1000+ Super USER!
  • 1,638 posts
  • KY
Posted 22 April 2009 - 09:26 PM
Three axles and all have the same problem tells me the problem is not with the axles. Failing bearing comes to mind.
#13 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 23 April 2009 - 07:46 AM
jack up and remove the wheel, place one hand on the spring and rotate the hub. you may feel the bad bearing in the spring vibration.
i think.
try a different wheel for comparison.
#14 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 23 April 2009 - 09:50 PM
i will try this tomorrow....hopefully this is going down the right path.
#15 hebrewhammer
hebrewhammer
    USMB Regular
  • PipPipPip
  • 87 posts
  • bellingham
Posted 29 April 2009 - 06:37 PM
finally got around to checking the bearings.
the right bearing is harder to turn than the left bearing however it sounds fine and i can't hear any prominent grind noises.
When listening to each bearing the left one seems to be in worse condition but still spins easier. Looks a little rusty around the bearing on the inside of the hub.....i feel like this is a teltale sign of failure.
sound about right...?
Also, any good tips on replacing the bearings....?
