sluggish 97 legacy
13 replies to this topic
#1 trialsguy
trialsguy
    New User
  • PipPip
  • 17 posts
  • oak grove
Posted 25 April 2009 - 12:15 AM
I have changed the fuel filter and plugs hoping that the car would have a little more pep. It does have over 200k so I am not expecting race qualities, just to be able to keep up road speed on long hills. If I accelerate it will take off then as it is speeding up under pedal pressure it actually starts bogging down slower, pulsing it would seem. I have never seen a check engine light come on. What are some things I can focus on and check out, I do have access to a code checker if my buddy has the right adapter for Subaru, I would have to check. Thanks
Edited by trialsguy, 25 April 2009 - 12:25 AM.
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,263 posts
  • East Coast
Posted 25 April 2009 - 06:01 AM
they can perform great at 200,000 miles, so don't write it off just yet.
what is the general tune of the engine? wires, air filter, PCV valve? has the timing belt ever been changed?
on the passengers side of the engine bay you should see a vacuum line going from the passengers side strut tower (it's connected to a sensor there) to the engine bay. close to the engine, just underneath and in front of the large air intake tube), you will notice a roughly quarter sized (but slightly thicker) small filter in line with the vacuum hose. they are $7 from Subaru, replace it.
Edited by grossgary, 25 April 2009 - 08:38 AM.
#3 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 25 April 2009 - 07:14 AM
As long as the engine is basically healthy (checked compression?), the mileage itself shouldn't be an issue.
As Gary already mentioned, air filter and PCV valve (and tubing) are things to look at. In addition, what you've described could be due to either a fuel delivery problem (insufficient fuel pressure/volume?) or possibly some exhaust restriction.
It's not likely that you'll find stored codes if you've never seen the CEL lit. The interface is standard OBD-II, so an adapter probably won't be needed for your buddy's reader.
#4 trialsguy
trialsguy
    New User
  • PipPip
  • 17 posts
  • oak grove
Posted 25 April 2009 - 01:47 PM
what is the general tune of the engine? wires, air filter, PCV valve? has the timing belt ever been changed.
I have had the car a little over 2 years and have replaced the plugs,fuel pump, fuel filter and air cleaner. I have no idea about a timing belt. I haven't replaced the wires or the pcv and didn't know about the small filter, what do you call it?
This filter that you speak of, is there not a replacement through one of the parts stores, I haven't looked online yet but I don't think there is a local Subaru dealer around.
Thanks a bunch for your help!
Edited by trialsguy, 25 April 2009 - 01:50 PM.
#5 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 25 April 2009 - 05:38 PM
Are you talking about this?
Posted Image
The one with the orange red connector on the top? I wonder how bad it was when I sprayed water directly over it and sprayed lots of silicone spray around that area? Never thought it was that important!
#6 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 25 April 2009 - 07:31 PM
replace the wires with OE.
You can have either a lazy knock O2 sensor (your way due for the front one so its not wasteful money to just get one from subaru). AN over hyper knock sensor, or a clogged cat. Hit the cat with your hand when it is cold, if it rattles its dead.
And yes at 200,000 miles you should still run close to new.
your also coming up for a timing belt change (every 106,000 miles).
nipper
#7 trialsguy
trialsguy
    New User
  • PipPip
  • 17 posts
  • oak grove
Posted 25 April 2009 - 08:57 PM
I think the filter they are referring to is a inline filter, that is attached to vacuum lines, or at least that's what I am guessing, Now I looked at it and pulled it loose to blow through it and it wouldn't allow air through either direction. Is this right? The thing I am referring to is attached to the valve or what ever that is you have indicated in your picture.
So if the cat rattles its clogged so do I do a cat delete type thing where I knock the guts out of it?
#8 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 25 April 2009 - 09:02 PM
Well if you have emissions inspection you need to replace it. i would prefer that if it is clogged it gets replaced.
nipper
#9 trialsguy
trialsguy
    New User
  • PipPip
  • 17 posts
  • oak grove
Posted 25 April 2009 - 10:48 PM
what does the little filter do? And do yo know what the name of it is so I can do some Google searches, Thanks!
#10 3Pin
3Pin
    Eat, Live, Breath Subaru
  • 459 posts
  • Milwaukee
Posted 26 April 2009 - 05:53 PM
From what I heard, The little filter wicks moisure so the sensor on the strut tower doesn't get damaged from the condensation in the vacuume lines and freeze in cold climates. I had one go on me and it was pricey. $7.00 is a cheap inventment.
#11 trialsguy
trialsguy
    New User
  • PipPip
  • 17 posts
  • oak grove
Posted 26 April 2009 - 07:08 PM
are you suppose to be able to blow through the filter?
#12 3Pin
3Pin
  • 459 posts
  • Milwaukee
Posted 26 April 2009 - 07:43 PM
I think so. I can check the one on my forester at the office tomororow.
#13 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 26 April 2009 - 10:06 PM
Before we start doing expensive things ....... go out and spend 20.00 on a vacume gauge and tell us what it reads and what it is doing.
nipper
#14 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 26 April 2009 - 11:10 PM
Checked the filter on that sensor. The housing was a bit dirty, but the filter itself was clean. Seemed like air was passing through it. I think I just need a new o2 sensor and axle.
