rough idle. sounds like a cylinder is "dead"
3 replies to this topic
#1 MaroonDuneDoom
    Stick It To The Man!!!
  • 604 posts
  • Casper,Wy
Posted 20 January 2004 - 07:34 PM
my ea82 engine has a funny exhaust rhythm. what i mean is it seems to glug instead of being smooth. i was told that a cylinder may be missing or really low on compression. does this happen with anybody else's car?
i checked the ignition system first. it's just fine. i don't own a compression test so i don't have too much to go by.
how can i find out what cylinder it is?
#2 bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 20 January 2004 - 07:39 PM
when idling pull a plug wire... if the engine drops significantly then that cyl has good compression/ign. try it with each cylinder (replacing the wire before going to the next) If you find a cylinder where the engine does not change much... That's gonna be your bad cylinder. Then it could be no spark to that cylinder or no compression for whatever reason.
#3 MaroonDuneDoom
  • 604 posts
  • Casper,Wy
Posted 20 January 2004 - 07:58 PM
thanks. never thought of that one.
#4 junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 20 January 2004 - 08:07 PM
be careful when you grab them wires cause you might find a wire and get what it's got :eek:
