uh oh, overheating and now oil leak
5 replies to this topic
#1 codytotheh
codytotheh
    USMB Regular
  • PipPipPip
  • 61 posts
  • up north, michigan
Posted 28 April 2009 - 09:42 PM
well its been intermittently overheating and then today it wouldn't go down in temp.
parked it and viola oil slick....
how boned am i and how do i do a head gasket ( my main suspect)
#2 codytotheh
codytotheh
    USMB Regular
  • PipPipPip
  • 61 posts
Posted 28 April 2009 - 09:48 PM
sorry just worked ten hours after this happened
'95 leg, sedan 5spd ej22
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,668 posts
  • East Coast
Posted 29 April 2009 - 05:42 AM
it probably wasn't the head gaskets at first...though they might be hosed now that you've driven it this long like that.
there's lots of other possible causes here, have you looked into this at all?
thermostat, water pump, hoses, clamps, leaks, bad radiator, fans not coming on.....
#4 Leg93
Leg93
    USMB Regular
  • PipPipPip
  • 61 posts
  • Salt Lake City - North
Posted 29 April 2009 - 09:24 AM
Yes, there are other possibilities, but when 2+2=4, you go with it. Are your fluids cross-contaminated (coolant in your oil, oil in you coolant)? Do you have full compression in all cylinders?
My Forester would overheat, then magically the temp would drop to normal. 5 miles later, repeat performance. No cross contamination of fluids. It was the HG. I was at a dealer the other day and he said that Subaru is recommending a silicone sealer instead of a replacement gasket for certain vehicles. Take it fwiw, but it might be worth checking out.
For my forester the mechanic had to pull the engine to do the work. Whenever you do the HG, you should check the head for flatness and do a valve job if needed. Even if not needed, it's a good time to tune them up. It cost me $1,800. 2 months later the car was totaled and insurance company gave me a $560 bonus for the work that was done. The machine work and checking tolerances is best performed in a qualified machine shop. You can remove parts and take them in, but in my case it wasn't worth it. I break stuff.
Hope this helps. Good luck.
#5 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 29 April 2009 - 11:03 AM
My guess would be the main or oil pump seal went and it was all down hill from there.
How much oil is in the crankase? When was the last time the seals were replaced.
I think you are quite boned.
#6 idosubaru
idosubaru
  • 23,668 posts
  • East Coast
Posted 29 April 2009 - 01:41 PM
that's what all EJ25 head gasket failures do. it's rare for them to mix fluids and if they do it's because someone beat the snot out of the engine. i've seen failed HG's even pass the sniffer test.
that's only for Phase II EJ25's (99+ foresters and 00+ Leg's). that's not for Phase I's, the failure modes of the two engines are completely different. Phase I - internal. Phase II = external.
