subawoohoo Posted January 21, 2004 Share Posted January 21, 2004 hey, on my '86 gl10, (didgidash) the gas, and temp guage as well as the trip computer are speratically acting up. occationally, the gas guage will show full, then later ill catch it just near empty, and it will hold there for a while (not sloshing arround.) the same goes for the temp, it will show about normal then, at the same time the gas guage acts up, it will show no temp at all. as for the trip guage, it will not do anything except look good. (no lights. buttons do nothing. completely useless.) then, a while later, ill look over and it will be working fine. im not getting this, its really annoying me. i thought i punctured my gas tank when i saw the guage while off roadin. lol so , has anyone else had this problem? some sensor? loose wiring? ugh, where to start? thanks, tyler. Quote Link to comment Share on other sites More sharing options...
calebz Posted January 21, 2004 Share Posted January 21, 2004 older digidashes are known for problems like you describe.. the solder on the back gets crusty and crappy.. on my 87, I had the dancing temp gauge.. but it did it in time with my heater fan.. the higher the heater fan, the higher the temp gauge.. I added some extra grounds off the negative terminal of the battery and all problems went away Quote Link to comment Share on other sites More sharing options...
subawoohoo Posted January 21, 2004 Author Share Posted January 21, 2004 that does sound like it could be the prob. is there any way to clean the contacts by removing the dash? meanwhile ill give the grounding a shot, thanks caleb ttyl tyler. Quote Link to comment Share on other sites More sharing options...
