axle bearing grease ?
2 replies to this topic
#1 tmonkey51
tmonkey51
    New User
  • PipPip
  • 22 posts
  • Santa Rosa
Posted 21 May 2009 - 12:42 PM
I have a 88 4d coupe d/r. The boot on the axle is leaking grease from the big side. My plan is too cut the clamp off, slam some wheel bearing grease in there and put a new hose clamp on it. I'm wondering if there is some special kind of grease in there or just regular grease? Thanks
#2 naru
naru
    1000+ Super USER!
  • 2,299 posts
  • under the bridge
Posted 21 May 2009 - 03:54 PM
You want CV joint grease.Slightly different.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,933 posts
  • Portland
Posted 21 May 2009 - 07:47 PM
It's an NLGI grade 2 with moly. It's black and slightly stringy. You don't have to buy the "CV" grease. That's a rip off. Just buy a tube of Moly grease - it will likely be grade 2 anyway as that's the most common.
HOWEVER. You should clean all the old grease out completely as they could be incompatible.
