Low on power
10 replies to this topic
#1 Guest_lazyNorm_*
  • Guests
Posted 22 June 2003 - 07:17 PM
I have a 99 2.5 Legacy GT auto with 52K miles. Lately it seems to be low on power. When I get into the gas, it doesn't have the kick that it used to. It also never seems to be in the right gear when going from a slow speed and then getting back on the gas. I almost have to floor it to get it in a gear that will accelerate. I have not had a check engine light or anything. Any ideas. The MPG are still good. I really don't want to take it somewhere and spend money to have some one tell me nothing is "wrong" or "that's normal" Any ideas will be appreciated. Thanks----------Dave
#2 Guest_meep424_*
  • Guests
Posted 22 June 2003 - 07:38 PM
what's its maintenance history?
#3 Guest_lazyNorm_*
  • Guests
Posted 22 June 2003 - 08:09 PM
I got it with 32K on it, I've put plugs and wires on it at around 45K. I also changed the tranny fluid at about the same time. Other than regular oil changes and such that's about it.
I put Bosch plugs in it, which I hear is a no no, but it still gets 20 -22 mpg which it has since we got it. Do you think I should pull a plug and see if its burning properly. Thanks ------------Dave
#4 Guest_remarcable_*
  • Guests
Posted 22 June 2003 - 08:34 PM
When was the last time the air filter was changed?
#5 Guest_lazyNorm_*
  • Guests
Posted 22 June 2003 - 08:55 PM
About 3-4 months ago. ---------Dave
#6 Guest_EOppegaard_*
  • Guests
Posted 22 June 2003 - 11:42 PM
Check to make sure there is no water in the fuel. You can do this by adding some gas line antifreeze/de-icer to the tank. Also check to make sure the fuel injection system is clean.
1993 Subaru Legacy Wagon "Flash"
#7 Guest_GlCraigGT_*
  • Guests
Posted 23 June 2003 - 03:20 AM
When was the last time the fuel filter was changed?
#8 Guest_lazyNorm_*
  • Guests
Posted 23 June 2003 - 02:13 PM
The fuel filter was changed less than a year ago. Like I said, I've kept up with maintainence. About how many miles does a oxygen sensor last typicaly. Will a bad O2 sensor give a CEL every time? Do the 99s have the the knock sensor problem I've read about some here. Just trowing some stuff out there for thoghts. Thanks--------Dave
#9 Guest_86Brat86_*
  • Guests
Posted 23 June 2003 - 08:42 PM
my dad has a 99 legacy L on his subaru dealership lot and it had a bad computer and it made it have a huge flat spot in it. only time you could get up and go is to the floor. hope this helps
#10 Guest_spagemurray_*
  • Guests
Posted 23 June 2003 - 09:12 PM
Auto-Rx performed wonders on my Mazda turbo and more so on MY00 Outback. NGK Iridium plugs are the go too IMO.
#11 Guest_lazyNorm_*
  • Guests
Posted 24 June 2003 - 01:40 PM
Did your dad have to replace the computer or did he have it reprogramed at the dealer or something? Thanks----Dave
