Emissions test failure - not ready codes
11 replies to this topic
#1 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Posted 03 June 2009 - 01:07 PM
I didn't get the full explanation.
But it sounds like it thinks codes were cleared in the not too distant past.
I haven't cleared any codes. But I did have the battery disconnected replacing the clock spring to get the Airbag light out.
Since then it has gone 2 trips probably 25-30 miles each.
CEL hasn't been on in the time that I've had it. I fixed a BAD oil leak, clock spring. LR window regulator, etc.
Put new NGK plugs in, changed oil and filter. Has Packard plug wires.
I didn't really know what to search for about getting this to reset. So I didn't find a good procedure.
What's the fastest ways to reset this so that I can hopefully get it retested today?
#2 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,920 posts
  • Near Cortland NY
Posted 03 June 2009 - 01:41 PM
I think you have to drive about 100 miles total, something like that.
I found this:
"Subaru recommends the following conditions and drive cycle to get the monitors on its vehicles completed in the shortest amount of time:
1. Make sure the fuel tank is between one-quarter and three-quarters full; half a tank is ideal.
2. Start the engine and immediately drive the vehicle for at least 15 minutes at a speed greater than 50 mph. During the warm up, try to avoid sudden acceleration, hard braking and/or lane changes.
3. Drive the vehicle at a steady 55 mph for three more minutes. During this stage of the drive cycle, it's crucial that you keep throttle angle changes to a minimum.
4. Bring the vehicle back to the shop, hook up the scan tool and look at the status of the readiness monitors. Repeat the drive cycle, if necessary."
I've also seen that the coolant must be seen to warm up 20 degrees or so, and hit at least 150 degrees or such.
Dave
Edited by CNY_Dave, 03 June 2009 - 01:48 PM.
#3 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 03 June 2009 - 02:05 PM
Someone told me to connect the 2 green connectors under the dash.
Drive 10-20 miles with the CEL blinking.
Disconnect them.
Get retested.
This is what I'm planning on trying
#4 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 03 June 2009 - 02:15 PM
I would suggest just going out for a nice "sunday" drive :)
spend an hour or 2 just exploring back roads or something.
#5 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 03 June 2009 - 02:20 PM
Sounds good. Sign me up!
Not a valid option for me unfortunately.
A lot of the reading about putting some miles/cycles on the car scare me a bit. I live in a decently hilly area. They want 30 minutes of 55 mph without the throttle angle changing? What are these engineers? How about a little real world reality please.
#6 OB99W
OB99W
    Elite Master of the Subaru
  • 3,315 posts
  • Ithaca
Posted 03 June 2009 - 02:24 PM
Proper drive cycle(s) will result in the I/M monitors status changing to ''ready'', as long as the ECU doesn't detect certain faults during the cycle.
#7 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 03 June 2009 - 03:02 PM
You can probably get away with a less exacting drive cycle. See: http://findarticles....n15871211/pg_3/
They're the people who design the car while having to contend with EPA regulations, among other things. The drive cycle that includes ''30 minutes of 55 mph without the throttle angle changing'' is suggested for the fastest way to be assured that all the monitors will be ready, but it obviously isn't the only way to accomplish that.
#8 subaru360
subaru360
    has no catchy title
  • 1,282 posts
  • Fleetwood, PA
Posted 03 June 2009 - 06:38 PM
What year is it? If it happens to be 96 it will never go ready. 96 is exempt from OBD2 in PA. Other years you just have to do the drive cycle.
#9 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 03 June 2009 - 07:07 PM
What year is it?
Good question. With all the other recent threads on this topic, I forgot to ask if this one was a '96.
Well, a '96 can complete the I/M monitors and be ready after a proper drive cycle -- but it won't retain that once the engine is shut off. If the car we're discussing in this thread is '96, see the links in my posts here: http://www.ultimates...ead.php?t=99635 .
#10 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 03 June 2009 - 07:25 PM
Appreciate all the thoughts.
This is a 99.
I plugged in the green connectors. Went to Sears/Walmart 25 miles away and back.
Dropped it at the inspection garage.
Tomorrow I should find out if it was reset. I didn't think to take my cheap OBDII scanner. Then again with no CEL I haven't had good luck with it finding "pending" issues even when I'm looking for them. Like after swapping O2 sensors with a used one, attempting to fix the wires on an O2 sensor, etc.
#11 idosubaru
idosubaru
  • 24,096 posts
  • East Coast
Posted 04 June 2009 - 07:54 AM
the cheap-o OBDII scanners won't detect the monitors i don't think so you didn't loose any time there.
i have never heard of the green test connectors clearing this issue, let us know if it works, i think i'd guess that it wouldn't. but i've lived in a non-emissions state for 3 years now what do i know?
#12 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 04 June 2009 - 11:06 AM
It worked.
Green connectors. 25 mile trip to go shopping and back with the CEL blinking the whole time.
Nothing not ready (there had been 3).
Passed emissions with no issues
