Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
P0106 code
Started by
marcd57
, Jun 18 2009 06:48 AM
6 replies to this topic
#1
Posted 18 June 2009 - 06:48 AM
Could use some help if anybody has seen this before. I bought a 97 Outback for my son from a supposed Subaru mechanic who had just swapped a 2.5L for a 2.2L. It drives and runs great but I found out the check engine light was burnt out so I changed it and now it stays on. Checked and now getting code P0106. I read about the missing vacuum lines that other people who swapped motors ran into, went to a junkyard and put those on correctly but still no luck. I cleared the code but it comes right back. Any help would be greatly appreciated.
Thanks, Marc
Thanks, Marc
#2
Posted 18 June 2009 - 07:17 AM
Welcome to the forum. I assume you're saying that a 2.2L (EJ22) was installed in place of an original 2.5L (EJ25). There was a recent thread which dealt with a P1143 code, which is very similar to the P0106. In particular, the resolution of the problem in that case might be helpful. See: http://www.ultimates...ead.php?t=99613
#3
Posted 18 June 2009 - 07:46 AM
Thanks. I don't know if the code was there before or not. Like I said, I didn't swap the motors. I checked the vacuum lines that I installed carefully and they looked good. Any tricks to testing/looking for small cracks? I guess my next try would be the baro sensor. The are 2 units that the vacuum lines are connected to on the strut tower, one is black (which I think is the baro sensor?) and one is a orange/rust color. Can you tell me which is which?
#4
Posted 18 June 2009 - 08:24 AM
If the vacuum hoses look okay, fit snugly, and aren't clogged, they probably are not the cause of the code.
The black part (nearest the fender) is the baro sensor, and the other is the ''pressure sources switching solenoid valve''. There should be an emissions label on the underside of the hood, which would show the parts and vacuum hose routing. Note that in the thread I linked to, the last post stated ''fixed problem, took barometic pressure sensor, from car i took, motor from, they were slightly different from 95 to 97,''. You might try to get a baro sensor for an EJ22 of the era of the engine that was installed. If you're getting parts from a JY, might as well pick up the solenoid valve as well.
EDIT: If you haven't already seen this, it might also provide some insight: http://www.ultimates...ead.php?t=84813
Edited by OB99W, 18 June 2009 - 08:43 AM.
Added reference to a past thread
#5
Posted 19 June 2009 - 02:40 PM
Found 2 vacuum lines crossed. Kinda fooled because it was running so good but no more codes.
Thanks
Thanks
#6
Posted 19 June 2009 - 03:01 PM
What a happy solution! Good for you. How did you figure out which ones were crossed?
#7
Posted 19 June 2009 - 03:16 PM
Yes, that was one of the solutions mentioned in the thread of the second link I gave.Found 2 vacuum lines crossed. Kinda fooled because it was running so good but no more codes.
Congrats, you're welcome, glad to help.Thanks
