Which AT's will fit a 98 OBW
4 replies to this topic
#1 BluetoE
BluetoE
    USMB Regular
  • PipPipPip
  • 72 posts
  • Deep South
Posted 24 June 2009 - 12:18 PM
Will any 4EAT fit? I'm afraid mine is toast after towing it almost 100 miles on a tow dolly with the FWD fuse in place and having an almost dead battery. There is a 93 Legacy at the local Pull A Part and I was wondering if it had a 4EAT?
According to Wikipedia:
"Usage: 1988-1991 Subaru XT, 1990-2004 Subaru Legacy, 1992-1997 Subaru Alcyone SVX, and all Subarus 1995-Present"
So does this mean the 93 Legacy AT will match up?
I really don't want to give up on this car...
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,018 posts
  • East Coast
Posted 24 June 2009 - 01:37 PM
that "definition" you posted is just a general note about the 4EAT transmission, which has gone through numerous changes.
the 93 legacy trans will bolt up and is identical in shape/form.
the 93 legacy will be the wrong final drive for your 98 OBW - it'll be a 4.11 where yours is a 4.44.
that being said, if you can use it if you grab a 4.11 rear differential to match.
those are two different generations, so i'm not positive but i'm pretty sure it will swap. i know someone has done this before, hopefully they post. or you can search for some threads here, i've seen it before regarding this exact swap.
#3 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 24 June 2009 - 02:21 PM
best choice, 96 - 98 outback
second best, 96 - 98 legacy GT or LSi, the speedo will be slightly off.
third best, 96 - 98 legacy L or LS, you will need the rear diff as well.
in a nutshell, any trans from a lego 96 - 98 with a 2.5L engine will work fine.
if it's from a 2.2L lego, you will need the rear diff too.
#4 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 24 June 2009 - 05:35 PM
You can also get the numbers off of the transmission and get one that way. On my 97 leg. with a 2.2 engine you can read the transmission numbers easy with the hood raised.
#5 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 25 June 2009 - 11:07 AM
Or you can take the transfer clutch pack an housing from the 93 and put it on your 98 to fix the smoked clutch pack, if it is actually burnt. Put a motor in it first and see if you trashed the transfer clutch pack or not. The car will still drive fine, it may just have torque bind.
