GEN 1 brake issue
1 reply to this topic
#1 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,832 posts
  • Dallas, Ft. Worth, Texas
Posted 25 January 2004 - 01:27 AM
Ok..I have done many brake jobs on Gen1's, but I am stumped on this one. I have so many NEW parts, I figured I better start to use some of them!
I REPLACED these items:
calipers/rotors/pads/mastercylinder/rear wheel wheel cylinders/adjusters/shoes/drums. I blead at least 1 gal of fluid, (blead master),adjusted the EMR brake and I still have just a marginal pedal! It's higher and firm with EMR brake all the way on, but better than 1/2 way down and "kinda" mushy without. It doesn't " sink though and the car stops ok.
Could air be still stuck somewhere? I get the feeling that it's air, but my god....I blead in proper sequence forever! Does the proportioning valve ever fail? I even put the old calipers back on and still the same pedal!!!
This has me totally frustrated!!
Ideas?
Todd
#2 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 25 January 2004 - 01:32 AM
Brake pedal travel is usually associated with the rears. Check your adjustment on the drums. It should have a slight drag or rubbing sound from the shoes contacting the drum. I know on the EA81 model brakes I adjust it until they bind and then back off one knotch.
Is the rod for the M/cyl threaded by any chance? If it is you can take some play out with it. But be careful with that one as you can force dragging brakes too.
