Who knows if 93 legacy seats will bolt right in to a 90 loyale????
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Do legacy seats bolt in to a loyale??
Started by
SuperBrat
, Jun 30 2009 08:46 AM
6 replies to this topic
#1
Posted 30 June 2009 - 08:46 AM
#2
Posted 30 June 2009 - 09:20 AM
Nope
#3
Posted 30 June 2009 - 09:26 AM
damn thanks!
#4
Posted 30 June 2009 - 08:19 PM
Im not sure if this will help,
my friend put xt seats in his 85 brat, they only bolted in the stock holes in 2 spots, and he drilled holes into a pieces of flat stock mild steel, and it moved the bolt holes over 2 inches.
If you do this use strong material,good bolts to keep it safe.
Its only a mounting point. you can make alot of thing work by bending the rules a bit.
But dont ever compromise on safety.
Good luck,
Good luck,
#5
Posted 30 June 2009 - 08:36 PM
Not exactly, as his Loyale and your friend's BRAT do not share common mounting points either.
But adapting other seats to fit your (insert model here) isn't always a difficult chore. If you have access to a pull-a-part yard (or similar equivalent), do this:
Take the seat rails off the underside of your Loyale. Measure two distances on the underside of the seat:
1) Distance, front to back, between the centers of the holes for rail mount on ONE side of the seat (either left or right).
2) Distance, side to side, between the centers of the holes for rail mount on either the FRONT or REAR of the seat. Pay special attention to this measurement.
When you go to the junkyard and find a seat you think you might like, unbolt it and take the rails off of it. Take the same measurements.
If #1 is a little off, it's not a big deal, quite easy to correct with a drill or dremel. If #2 is off, it can be a pain to correct (requiring cutting/welding and/or custom mounting blocks). So try to find a seat where the side-to-side measurement is the same.
Read the following thread for an idea of what I'm talking about. Though this was done on my BRAT, the principals apply to a Loyale, they just require finding different seats where the side-to-side measurement is a better fit. http://www.ultimates...at protege seat
#6
Posted 30 June 2009 - 11:04 PM
Here's something else I also discovered.
If the seats have alot of adjustments to them, they might turn out to be to tall.
The Mazda seats I got were both to tall, especially the drivers seat.
So make sure before you pull them out of the donor to see how far off the floor they are mounted. If they are almost on the floor, its a good chance they will be to tall for a Subaru.
#7
Posted 30 June 2009 - 11:39 PM
You just make some adaptors from flat-bar, weld them to the EA82 rails and then bolt the new "adaptor rail" to the seat of your choice. It's not that difficult.
