i would definetly be interested in that for my rx. i got 50 bucks.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
A discussion on fuel for the EA82T, to be focused on FUEL RAILS
Started by
Subarutex
, Jan 25 2004 09:25 PM
32 replies to this topic
#26
Posted 30 January 2004 - 12:52 AM
#27
Posted 30 January 2004 - 08:26 AM
Pending on whether or not i get a certin IC...and a hard drive...I'll have $50 in my paypal. the more i think about this, the more i want to do this.
I *KNOW* i wont have the time to make something like this, much less find all the stuff to make it.
#28
Posted 21 November 2004 - 06:45 AM
Whatever became of this project SubaruTex? This story never ended. *Old Post Bumpay*
#29
Posted 21 November 2004 - 10:12 AM
also i was thinkin the other day. maybe use an xt6 intake, with the two rear runners cut out and filled in. its set up for bigger injectors, on a fuel rail, and has a big tb.
#30
Posted 12 January 2005 - 01:29 AM
another bump.... we're curious, tex!
#31
Posted 12 January 2005 - 02:15 AM
The car has ran for sometime on the my fuel rails.
Lemme find a picture and I'll post it here.
Oh, and I have about $450 into my fuel system. And no, i'm not gonna sell them. There wasn't much interest, and I would be hard pressed to do them for $50 a set. Then you'd have to buy all the hose, fittings, new pressure regulator...
Andy, no idea on emissions, its not due till this next august. Who knows if it will even run by then.
BTW, those that don't know, the car is not running currently do to leaky HG's.
*edit* PICS!
http://www.subarutex...uel-System-Pics
*edit* PICS!
#32
Posted 12 January 2005 - 07:28 AM
Leaky headgaskets again?
#33
Posted 12 January 2005 - 11:23 AM
I made myself a "fuel rail" last week and so far it seems to run and not leak...we'll see how it will actually do in performance applications.
My main concern with the stock set-up is the issue of un even fuel pressure and flow to all the injectors. i have a hunch that the Pass side bank of cylinders isn't getting enough pressure and flow....especially #3.
What i did. was i found an "air distribution block" It has one input port, and 4 output ports... They are tapped for 1/4" NPT fittings. I then drilled out the end plugs and tapped them also.
It looks kind of like this.
Feed from filter
V
Pressure Gauge ----[=============] ------- To Fuel Pressure Regulator
V V V V
INJECTOR OUTPUTS
I made an effort to keep all the output lines to the injectors very close to the same length.
Someone suggested that if i ran the car out of gas i would be cranking forever....however i don't think so as the fuel rail and lines were completely dry when i installed this (obviously), and it started right up....so i don't really see a problem.
The Distribution block is mounted in the space previously occupied by the Spare Tire.
Feed from filter
V
V V V V
INJECTOR OUTPUTS
