transmission removal
30 replies to this topic
#26 DupermanDave
DupermanDave
    USMB Regular
  • PipPipPip
  • 100 posts
  • Northern CO
Posted 17 July 2009 - 11:52 AM
methinks I should have left the transmission bolts off and sprayed the crack with pb blaster and let it sit until sunday. Maybe gravity would have worked on it just letting it sit.
Would it be bad if I just hooked a tow strap around it and hooked it to the bumper of my truck and slowly let the truck creep down the driveway and have someone watch the transmission and see if it will pull apart?
#27 Fairtax4me
Fairtax4me
    Su bah roo'n
  • Gold Subscribers
  • 6,211 posts
  • Charlottesburg, VA
Posted 17 July 2009 - 12:02 PM
I think you'd be asking for trouble doing that. No doubt it would work, but when it pops loose what's it gonna hit first? You also run the risk of just pulling the car off the jack stands.
Be absolutely sure you get all of the fasteners out and work your way around it with a pry bar. That's the best and safest way.
#28 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 18,061 posts
  • West VA
Posted 17 July 2009 - 12:09 PM
Yeah I wouldn't do that. Ratchet may also break and you'll need new glass somewhere. Brute force would require a lot of it. When you work it loose you do a little at a time and one small part at a time...applying all the force necessary to separate all at once sounds awfully risky.
It is totally normal for the engine/trans to be VERY tight. Hammer and chisel are standard fare for an operation like this.
#29 davebugs
davebugs
    I don't "friend"
  • 3,078 posts
  • Pittsburgh suburbs (NE)
Posted 17 July 2009 - 12:31 PM
I start with the PB.
Long shafted thin screw drivers from Sears (several now have bent ends).
Work up the more regular screw drivers, then huge ones.
I always try and get the drivers side to be the "lead". Since it's the most congested area and often that roll pin is the most stubborn.
Anything involving a truck to seperate them isn't a good idea.
Make sure the motor mount bolts are free of the cross memebr and TC bo9lts are out(if an auto).
Cardboard infront of the rad/condensor.
#30 DupermanDave
DupermanDave
    USMB Regular
  • PipPipPip
  • 100 posts
  • Northern CO
Posted 17 July 2009 - 02:58 PM
Yeah, I just now thought about that. If it's really stuck on there, it may start to drag the car back with it.
I'll just tie the strap to my dog and have him pull it. He's strong enough.
On my suzuki when we had this problem it turned out there was a dirt shield connecting the bell housing to the engine. Nowhere in the manuals did it mention this. We eventually just shreded the metal around the bolt holes and pulled it free. So for this project I made sure there was nothing else connected. No plates or hidden bolts. There was one support bracket at the very top of the transmission that holts it to the firewall. What is this for?
#31 guydakine
guydakine
    New User
  • Pip
  • 9 posts
  • Paia Maui
Posted 28 December 2009 - 05:57 AM
Hi all,
Got a new '02 Forester with a bad automatic transmission, found a good used one for cheap and doing the swap as we speak. Couple quick questions and will add some more tomorrow night after working on it all day with newer issues I'm sure.
The old trans had code#TZ1A3ZC3AA-PM,,, the new trans, also an '02 has code#TZ1A3ZC2AA-P8,,, the only difference being the 3AA to 2AA and PM to P8, I was told it would be a perfect match, any issues anyone knows of please let me know..
Also, I did an engine swap on a '96 Outback with an auto trans as well, it was a bi at ch but had success without ever opening my new Haynes manual! Sold the Outback with the manual....
So first do the axles need to be freed from the ball joint in order to swing out free for removal??
Also most pics I'm seeing posted don't really show in detail the torque converter bolt up and alignment procedure. What should it line up with and how do I know where I'm at in relation to the engine/trans being inline??? So afraid of what I've read about the transfluid pump.. When I did the Outback it was a miracle I didn't ruin it, as I aligned the bolts to TC using a screwdriver to move the flywheel, it clunked loudly into place, meaning I was just about to destroy my pump for sure.. If any of this makes sense please reply to it, I'll check it in the morning and will pick up a manual as well. Thanks..
