93 Legacy front door speaker replacement.
6 replies to this topic
#1 Guest_97svx_*
  • Guests
Posted 22 June 2003 - 01:39 PM
I am trying to upgade my tired OEM speakers but the spacer which angles the speaker is made out of thin metal and is unuseable. What can I use in its place?
#2 Guest_Sydfloyd44_*
  • Guests
Posted 22 June 2003 - 02:53 PM
Can't answer your question but will recommend you be careful that you make sure the door glass will clear the new speaker. I replace a lot of door glasses and regulators because this caution is not taken. Usually happens when the glass is put down for the first time after the install and the auto-down feature is used. CRUNCH!!
Many subes have limited depth clearance when replacing factory speakers. Spacers will probably have to be used.
#3 Guest_Legacy777_*
  • Guests
Posted 22 June 2003 - 03:12 PM
just get some normal plastic spacers. They'll work fine.
#4 Guest_97svx_*
  • Guests
Posted 22 June 2003 - 03:22 PM
Josh, where do I get these magical spacers? I called a local specialty shop and visited Walmart without success.
#5 Guest_Legacy777_*
  • Guests
Posted 23 June 2003 - 06:34 AM
should be able to get them at a local stereo shop. What neck of the woods you live in?
A circuit city, car toys, best buy should all have them. You'll probably have to ask their install people, or ask one of the salesman to go get them from the install bay.
#6 Guest_97svx_*
  • Guests
Posted 23 June 2003 - 06:48 AM
Josh, thanks. I am in NJ and there is a Circuit City nearby.
#7 Guest_edrach_*
  • Guests
Posted 23 June 2003 - 08:05 AM
Most any hardware store will have a supply of a variety of plastic spacers.
