Jibs Posted August 10, 2009 Share Posted August 10, 2009 Can you run an rx FT4WD tranny in Rear Wheel Drive without harm or no? has anyone tried it? Pro's/Con's? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 10, 2009 Share Posted August 10, 2009 not any more than a PT4WD trans. the transfer gears will be strained, but as long as you don't drive like a total nutcase, it'll work. the locker is not the weak link. I ran my RX trans for about 8k miles in FWD (only had the front half of the driveshaft). I've put about 30k on it since then, locker still works great! Quote Link to comment Share on other sites More sharing options...
Jibs Posted August 10, 2009 Author Share Posted August 10, 2009 not any more than a PT4WD trans. the transfer gears will be strained, but as long as you don't drive like a total nutcase, it'll work. the locker is not the weak link. I ran my RX trans for about 8k miles in FWD (only had the front half of the driveshaft). I've put about 30k on it since then, locker still works great! Thanks a bunch. That helps a lot. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 11, 2009 Share Posted August 11, 2009 Can you run an rx FT4WD tranny in Rear Wheel Drive ?yes. it'll be fine. the folks that have never done it will tell you horror stories that those of us that have done it have never experienced. so...limited (anecdotal?) experiences or armchair quarterbacks, take your pick! :lol: like chux said, i wouldn't pound the thing. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted August 11, 2009 Share Posted August 11, 2009 You have to run it with the center differential locked. Quote Link to comment Share on other sites More sharing options...
Jibs Posted August 12, 2009 Author Share Posted August 12, 2009 Thanks. I was wondering if I had to have the center locked or not. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 12, 2009 Share Posted August 12, 2009 Definatly need to have the center locked. If you don't, the diff acts like any other open diff, and it will just send all the power to the front (since there are no axles there). Even locked, would still be real careful. But im not sure what it actually uses to lock the center diff, and how strong it all is. No luck on front CV's i take it?? Quote Link to comment Share on other sites More sharing options...
Jibs Posted August 14, 2009 Author Share Posted August 14, 2009 Definatly need to have the center locked. If you don't, the diff acts like any other open diff, and it will just send all the power to the front (since there are no axles there). Even locked, would still be real careful. But im not sure what it actually uses to lock the center diff, and how strong it all is. No luck on front CV's i take it?? Not yet. Still working on it. This is plan Z. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted August 14, 2009 Share Posted August 14, 2009 Gotchya. We're running out of time! Quote Link to comment Share on other sites More sharing options...
baccaruda Posted August 14, 2009 Share Posted August 14, 2009 What's up with the front CVs? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 15, 2009 Share Posted August 15, 2009 we drove 5500 miles cross country and back in an 87 rx with the diff locked in FWD, because we had to remove a rear axle, because one of the wheel bearings were bad and we rode with an xt6 5 lug on the one side. had no problems, but we were running FWD Quote Link to comment Share on other sites More sharing options...
Niku-Sama Posted August 16, 2009 Share Posted August 16, 2009 i've run FWD fully loaded over mountian passes for about 50 miles and i didnt have any problems either but i think its a big easier for it to run in FWD than RWD although i like RWD alot better but i have another car for that Quote Link to comment Share on other sites More sharing options...
