pearlm30 Posted August 13, 2009 Share Posted August 13, 2009 I have an engine hoist but I dont know where to get the lifting chain for engine swap. I looked thru the harbor freight store and all their metal chain has disclaimer that its not for overhead lifting. So can anyone recommand the correct type of chain to use with a engine hoist for engine swap? Thanks Quote Link to comment Share on other sites More sharing options...
davebugs Posted August 13, 2009 Share Posted August 13, 2009 I use a beam that has 2 short chains. Has a crank to change the fulcrum(?) point to change the pitch of the engine. I think it was 50 bucks? Most auto parts that carry "engine crane's" have them. Otherwise I'd just go to the hardware store. Noone will be under the engine anyways. You're assuming the risk though. Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted August 13, 2009 Share Posted August 13, 2009 An adjustable beam like Dave's got is really the ticket. But if you can't find that or you are far away from everything in the world, http://www.mcmaster.com/#lifting-chain/=36ahh9 Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted August 13, 2009 Share Posted August 13, 2009 (edited) you can also use climbing rope or web strapping....for a subaru engine, not a big block.... Edited August 13, 2009 by bheinen74 Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted August 13, 2009 Share Posted August 13, 2009 As long as the edges you're lifting from aren't sharp, climbing rope would be fine for any engine that doesn't require a commercial license to drive the vehicle it's from. The tensile strength of climbing rope is several thousand pounds. I suggest using static rope though as the stretch in dynamic rope can be irritating. While I have used climbing rope for all sorts of activities (climbing included!) I'm not advocating it as a "safe" alternative to the appropriate tools. As always when you are dangling several hundred pounds in the air, use the right tools when available. Quote Link to comment Share on other sites More sharing options...
davebugs Posted August 13, 2009 Share Posted August 13, 2009 If you're lifting a 2.2 or 2.5 there is a tab where the eng/trans meets by where you disconnect the wireing on the back. Then on the drivers front I use the alternator bracket where the AC compressor was. Doesn't perfectly balance but it's not bad. Neither of those are sharp. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 13, 2009 Share Posted August 13, 2009 Use lifting straps - chain is not the prefered method for overhead lifting these days. Nylon/synthetic straps are better. Typically for an unbalanced load I use one or two straps and a small come-along to level it. GD Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted August 14, 2009 Share Posted August 14, 2009 I just use whatever chain I have laying around... Usually nothing smaller than 5/16" diameter links, but I have used smaller... Ive pulled Big Block Ford and Chevy motors with the same chains. On a Subaru engine that I can pick up myself, I really dont see the risk being that high... When I buy new chain I get it at Ace becasue its closer, but If I wanted like Grade 8 strength I could go to my local farm fabrication shop, they can get anything... But like I said, what I used works... -Bill Quote Link to comment Share on other sites More sharing options...
Greenley Posted August 14, 2009 Share Posted August 14, 2009 I use the same beefy, made in USA, $2 garage sale, six-foot length of chain that i carry when wheelin'. Right now i'm using a tow strap, come-along, and said chain supported from my garage rafter beams. You're over-thinking Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted August 19, 2009 Share Posted August 19, 2009 I just lifted a 2.2 with a nylon tow rope. Worked just fine. And use manpower to level it out. That's all that I did. And you can knot a tow rope Twitch Quote Link to comment Share on other sites More sharing options...
Qman Posted August 19, 2009 Share Posted August 19, 2009 I have braided steel cable to lift engines with. Slides along the engine hoist hook for proper positioning and is looped for fitment almost anywhere. Unfortunately, I do not remember exactly where I got them from. I have three different lengths for all engines. A few members have seen them in action and will confirm how nice they work. Now, to answer the original question. You can buy chain at the local hardware, most rental stores and trucking stores will also have a decent selection. Quote Link to comment Share on other sites More sharing options...
