mtnman38 Posted August 20, 2009 Share Posted August 20, 2009 1992 2.2 in exstended cab 1982 brat OK so ben and i finally got the 2.2 swaps complete . he got rearended so his is dead and mine is pouring gas into the oil somethings i thought it might be ,I just thought i would run it past ya all first the fuel pump is hard wired to come on with the key the largest hose that goes from the throttle body back to the intake hose is plugged up, because if it open i have a huge vacum leak so let me know if any of yall have had this problem and yes i did a search and ihave to say that thing is very poor try searching for gas in oil it says its to common of a term so i tried re wording and wording it and wording it and wording it all that got me is a broken monitor:mad: thanks in advance Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 20, 2009 Share Posted August 20, 2009 search doesn't play well with 3 letter words. try adding a * to either end of a three letter word, sometimes that works. *gas or gas* might actually show some results. not sure about: *gas in *oil or similar combinations but give it a whirl. how do you know there is gas in the oil? Quote Link to comment Share on other sites More sharing options...
davebugs Posted August 20, 2009 Share Posted August 20, 2009 I don't do these kinds of swaps. But gas in oil is typically one of 3 things. Bad fuel pressure regulator Injector is bad and/or leaking down Fuel return line is plugged. Quote Link to comment Share on other sites More sharing options...
mtnman38 Posted August 20, 2009 Author Share Posted August 20, 2009 thanks for the intel ill try those things is there any way to test an injector to see if its leaking? Quote Link to comment Share on other sites More sharing options...
