Can I get some good advice about a OBD code P0440. I know that it is the evap control sys but what do I do now??? Also I need to know where the different parts are located on the car. This is a 2000 Forester L. Please Help:
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
P0440 error code OBD
Started by
Wicket
, Aug 20 2009 03:45 PM
4 replies to this topic
#1
Posted 20 August 2009 - 03:45 PM
#2
Posted 20 August 2009 - 04:02 PM
Welcome to the forum. These should get you started:
http://www.endwrench...InsiderInfo.pdf (beginning on page 22)
http://endwrench.com...TipsInfoW00.pdf
Edited by OB99W, 20 August 2009 - 04:05 PM.
#3
Posted 21 August 2009 - 05:44 AM
2000 Subaru ...... could be a rusted filler neck. Something to inspect.
Remove the passenger rear tire. Remove the plastic shield covering the filler tube, usually 2 or 3 small bolts. Then clean away the debris and look/smell carefully. The filler tubes DO rust through and post a P044x code.
Some have not replaced the cover after replacing the filler pipe. Their choice. I would prefer to remove it, clean under it and reinstall. Maybe make it part of the 60k service. The cover is there to prevent damage from road debris especially those pieces flipped up by the tires. So it does have a purpose other than to trap debris and cause the filler to rot.
#4
Posted 21 August 2009 - 02:59 PM
You are the man!!!! After following your advice I found a small hole in the filler pipe. There was a lot of crap after removing the cover. Now I have to find a pipe and replace it. Thanks again.... Wicket
#5
Posted 11 October 2009 - 03:17 PM
How did this work out for you? did the check engine light go off after you fixed the filler tube?
