Does this sound like a slipping belt?
17 replies to this topic
#1 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 22 August 2009 - 07:15 PM
95 legacy wagon As you might be able to see in the video I have 208K
#2 Suzam
Suzam
    1000+ Super USER!
  • 1,224 posts
  • Wilmington, Delaware
Posted 22 August 2009 - 07:24 PM
Hard to hear but that sounds more like a heat shield to me.
#3 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 22 August 2009 - 07:28 PM
You don't hear the squeal?
#4 OB99W
OB99W
    Elite Master of the Subaru
  • 3,315 posts
  • Ithaca
Posted 22 August 2009 - 08:07 PM
Make sure that the crank pulley isn't loose or wobbling -- it's a common cause of accessory belt squeal. If that's okay, and you want to verify the noise is coming from an accessory belt, lightly spray the belt with water. The noise will stop or change significantly while wet.
#5 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 22 August 2009 - 08:10 PM
Well I changed the T-belt about 5 months ago I brought a Tq wrench just for that job.. I can check again but I doubt it got loose since I had a Subaru meet and I saw first hand what happens when a crank pully will eat up the key.
I will try the spray tomorrow morning.
#6 subaruguru
subaruguru
    Scammer
  • 1,642 posts
  • Yakima Wa,
Posted 22 August 2009 - 10:15 PM
my 2.2 was making a noise like that turned out to be the PS pump went out it had alot of shaft play
#7 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 22 August 2009 - 10:20 PM
Hmm the pump does have a little leak.. never thought it would be something like that given how free the pulley spins without a belt on it I'd figured it would make the sound way before it got that high..
I will check that too tomorrow providing we don't get flooded out what's left of this hurricane.
#8 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
  • Charlottesburg, VA
Posted 23 August 2009 - 01:36 AM
Loose belt. But check the accessories to make sure they spin free anyway. Might be an alternator or AC clutch getting ready to lock up.
#9 Pontiac6KSTEAWD
Pontiac6KSTEAWD
    USMB is life!
  • 170 posts
  • St Louis
Posted 23 August 2009 - 02:33 AM
My 2.5 01 Legacy does it too. Both with the old engine, and the new engine. We gave up trying to track it down. One shop suggested the sychros in the tranny. But in Neutral? it just didnt make sense.
#10 subaruguru
subaruguru
    Scammer
  • 1,642 posts
  • Yakima Wa,
Posted 23 August 2009 - 04:01 AM
mine only did it at 4 or 5 Gs
#11 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 23 August 2009 - 11:02 AM
Ok took off the belts.. now here is the really weird part...
If I move the throttle from the engine bay no squeal at all.. but if I move the throttle from inside the car I get the squeal...
Any guesses? I'd need a 2nd person to film while im in the car since I can't find my tripod plate :mad:
#12 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
Posted 23 August 2009 - 11:35 AM
That does seem strange. Can you tell for sure that the squeal is coming from the engine bay?
#13 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 23 August 2009 - 11:41 AM
Yes it does sound like it is however I can't narrow the sound down more until I get someone to hold my camera.
after putting the belts back on I went on the highway and hung around 4K when it started and proceeded to test if i backed off a little but still on the throttle it would go away but as soon as I gave a little more throttle the sound was back..
As you can see it's fairly loud.. WRX owners say it sounds like a Blow-Off valve.
#14 Pontiac6KSTEAWD
Pontiac6KSTEAWD
    USMB is life!
  • 170 posts
  • St Louis
Posted 23 August 2009 - 04:28 PM
With what you just discribed, it sounds like it might be the tranny input shaft bearing.
However, if it is, I am not sure I would worry alot about it. My 01 has been making that sounds for over 65000 miles, and still runs cherry.
#15 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 23 August 2009 - 04:31 PM
but why would it only make the sound when i pressed the throttle in the car but not make the sound when moving the throttle from the throttle body?
#16 Pontiac6KSTEAWD
Pontiac6KSTEAWD
    USMB is life!
  • 170 posts
  • St Louis
Posted 23 August 2009 - 04:33 PM
The only thing I can think of is that under throttle, you have more rotation, or tq thrust. But in either case, I really cant explain it either. I have been tracking down this sound on my 01 for years. I gave up.
#17 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 23 August 2009 - 04:37 PM
When you press the throttle in the car, are you sitting in the car? What happens if you remain outside, but reach in and press it? (In other words, is your weight on the seat perhaps shifting something?)
#18 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 23 August 2009 - 04:41 PM
Sitting in the car or pressing it with one foot while standing at the door.
This has become a big mystery now since I thought it would be pretty easy to track.
