6 lug conversion
3 replies to this topic
#1 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 28 January 2004 - 10:27 PM
are the hubs strong enough so that if you grind down the hub to properly seat the lugs on a 6 lug conv. that they won't crack or should i weld up the low spots and drill the hubs that way?
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,922 posts
  • Portland
Posted 28 January 2004 - 10:32 PM
You don't have to grind them at all. They will still pull up fine once you tighten them down. And unless your doing it for mags, drilling the rims is definately easier. Many, many people are running drilled rims, and put them through hell. I've never heard of one breaking, except from improper installation.
#3 Rossta86
Rossta86
    USMB Regular
  • PipPipPip
  • 56 posts
  • Northern VA (Woodbridge)
Posted 28 January 2004 - 10:39 PM
The way i did my 6 lug conversion was I frist drilled the hubs with a 9/16 bit? I think that was it. I had too grind down some of the sides of the studs to make them fit better. Then i actually ran it for atleast 500 miles with studs loose in the drilled holes. It does fine aslong as the lugs are tight. Once i got my welder and be came comfortable with it, i pulled my hubs off, bolted them to the wheel, then filled in the low spots and put a bead around the studs. One can argue which is better (drilling the hub or rim), but im just stating that this way worked fine. I probably would have drilled the rims, except the style of yota wheels i got could not be drilled right. I don't think i would try to grind the hub itself down, just because the metal is pretty hard.
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 29 January 2004 - 12:16 AM
my example was to use chevy 6 lug rims, like on 1/2 ton 140mmx6
what i did was use a soob hub, pop out 2 opposite studs, and then bult it to the rim. then i used the hub to drill through the rim, and i uses 21mm lug nuts, that still have the subaru m12 1.25 thread, and 60 deg seat. i had to grind away the center of the rim to fit the hub
there are other rims that will work, toyotas and such. im sure someoner can tell you about those.
but i say use a rim that is suitable to drill through, if you go that route
http://www.warpthree...sedanwheel.html
http://www.warpthree...XDoorsOpen.html
Posted Image
