How tight
9 replies to this topic
#1 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,998 posts
  • West Des Moines, IA
Posted 30 August 2009 - 10:41 PM
My newly brakes are working good but i noticed some squeeking and popping on one of the sides. I can wiggle the wheel around alittle. When i pop off the wheel the castle nut is on but i can wiggle it back and forth. Seems the cotter pin is holding it onto the hub mostly. How tight does this need to be
#2 markjw
markjw
    Elite Master of the Search Function
  • 828 posts
  • Lacey,Wash.
Posted 30 August 2009 - 10:46 PM
You mean the 36mm castle nut on the end of the axle? I stand on um with a breaker bar and I'm over 200lbs. So,basically,as tight as I can get um. That works for me.
#3 zukiru
zukiru
    EJ22T
  • 1,229 posts
  • Oak Grove, AL
Posted 30 August 2009 - 10:48 PM
I read 150 ft pounds... but I didn't have a TQ wrench that big so I just tightened really tight..
so far so good... did you recently do the bearings? (fi not the may have failed)
#4 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 30 August 2009 - 10:59 PM
no i recently put on rear disc brakes so i had all that mess apart. Its not squeeking though or rattling. Ill get it tightened on more and yet you know if that was the problem. Its not a constant squeek or rattle i should say. Just sounds like something is loose. Yea it definately doesnt have 150 lbs or torque to it.
#5 The Beast I Drive
The Beast I Drive
    CALL ME, (509) 391-5903
  • 2,120 posts
  • Toppenish, WA
Posted 30 August 2009 - 11:24 PM
Yeah you want those to be tight, really bad stuff can happen when they are loose...
-Bill
#6 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 30 August 2009 - 11:48 PM
Ill get right on that next weekend.
#7 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,933 posts
  • Portland
Posted 31 August 2009 - 12:18 AM
150 ft/lbs is the spec for all the 36mm axle nuts.
#8 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 31 August 2009 - 08:07 AM
you need the socket?
#9 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 31 August 2009 - 11:06 AM
Yea ill try my local guy first.
#10 The Dude Abides
The Dude Abides
  • 2,998 posts
Posted 04 September 2009 - 12:37 AM
Local guy didnt have the socket so i had to buy one. Right hand side took 7 turns to reach 150lbs:eek: Left side took 1 and a half. All is well and nice and smooth. Thanks for the help all.
