repair hole in fuel filler neck
10 replies to this topic
#1 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,008 posts
  • East Coast
Posted 01 September 2009 - 08:44 AM
1996 Legacy the fuel filler pipe is in decent shape but has a small pin hole in it.
What say ye about repairing it? Doesn't look worth replacing to me. I've already wire brushed, treated, and painted it. Now to plug the hole?
#2 Rooster2
Rooster2
    Subaru Master
  • 4,722 posts
  • Indianapolis
Posted 01 September 2009 - 09:00 AM
Repair with JB Weld, available at auto parts store. Works great!
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 01 September 2009 - 10:48 AM
JB weld, fuel tank repair epoxy. You could even solder/braze a patch on if you're really good with a torch. JB is quicker though.
#4 Rooster2
Rooster2
    Subaru Master
  • 4,722 posts
  • Indianapolis
Posted 01 September 2009 - 11:30 AM
IMO soldering/brazing on the neck of a gas tank with a torch is a bad idea. Just too easy to cause an explosion from the gasoline fumes.
#5 idosubaru
idosubaru
  • 24,008 posts
  • East Coast
Posted 01 September 2009 - 11:38 AM
yeah i thought about welding....for 2 seconds. i forgot to mention it's still on the car.
i'll look for fuel repair stuff or JB weld if that's not available. probably very similar to each other anyway. low stress, low heat, should be simple.
#6 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
Posted 01 September 2009 - 10:48 PM
I never said to do it while its on the car. :-p
Although if you filled the tank with gas all the way to the very top of the tube you could. :grin: (maybe)
#7 Lefty
Lefty
    New User
  • Pip
  • 9 posts
Posted 02 September 2009 - 11:44 AM
2000 OBW, 130,000
I have been wanting to do some prevent maintenance on the fuel fill pipe. My tech told me to clean it and spray undercoat on it. I'm not much of gearhead and I am having a hard time getting to it. Can someone tell me how to get at it properly? Maybe some illustrations?
Thanks in advance
Lefty
#8 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 02 September 2009 - 12:19 PM
Today's lesson on welding a gas tank will be dropped. No need to kill anything or someone.
#9 idosubaru
idosubaru
  • 24,008 posts
  • East Coast
Posted 02 September 2009 - 01:37 PM
it's really easy to get to - remove wheel, remove plastic cover. it's REALLY simple.
#10 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,912 posts
  • Near Cortland NY
Posted 02 September 2009 - 03:03 PM
Todays 'don't do this but it's safe':
I had a 1983 yamaha Seca 900 (XJ900RK) and there was a chunk of gas tank space that was not usable because a collar extended down into the tank, with a very small bleed-hole at the top of the collar. If you filled up beyond the bottom of the collar, you had to drip the gas in because the bleed hole was so small.
I decided to drill the bleed hole larger, so of course the question is-
1) remove tank and purge of fumes
2) do it on the bike, tank with only a little gas in it
3) do it on the bike, filled up all the way
I'm too lazy to take the tank off the bike, so obviously I did (3).
Dave
#11 EVOthis
EVOthis
    1000+ Super USER!
  • 1,392 posts
  • Kennett Square PA
Posted 02 September 2009 - 06:21 PM
+1 ^ Epoxy or JB Weld...
