EA82 spare tire
11 replies to this topic
#1 sub87dl
sub87dl
    USMB Regular
  • PipPipPip
  • 31 posts
  • Cleveland, OH
Posted 29 January 2004 - 11:55 AM
Does anyone actually inflate the EA82 spare tire up to 60psi? I took mine off the car while doing some engine work, and checked the pressure, only about 33psi. But since it came stock with the car back in '87, I'm a little nervous about taking it to the service station and inflating it to 60. All that air inside that little tire!?!?
What experiences do people have with this?
Luke
#2 Hogsubie
Hogsubie
    Eat, Live, Breath Subaru
  • 266 posts
  • Northwest Arkansas
Posted 29 January 2004 - 12:25 PM
You'll be fine to inflate it to 60psi, unless your tire is really dried out and cracking. 60psi is not uncommon for spares. Just think of a 10 speed bicycle, they have really skinny tires and you inflate those to 60 +/- psi.
#3 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 29 January 2004 - 01:00 PM
if you don't put 60 lb of pressure in it. it would be like running 15 lb in your full size tire and if you hit a pot hole with it it'll probably bend or blow out
#4 Partsman
Partsman
  • 262 posts
  • sunny Eugene, OR
Posted 29 January 2004 - 09:10 PM
Sheesh! I have a full sized tire and rim under the hood so I can actually drive if I need a spare. Temp donuts suck big time - can't drive normal speeds, can only drive a little ways before they are toast, etc. I would ESPECIALLY not trust the donut that came with the car! Rubber gets old and can fail at any time.
#5 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 29 January 2004 - 09:38 PM
I have the original doughnut in my 84 Brat and have used it on more than one once. I delivered pizza one night on my spare in the snow with no problems.It is a good idea to check your spare tire's air pressure on a regular basis. I check mine when I change the oil.It is an easy thing to overlook but a flat spare just adds injury to insult.I keep mine at 60 PSI.
#6 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 29 January 2004 - 09:41 PM
I meant insult to injury
#7 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 29 January 2004 - 09:59 PM
I have both.. a never been used donut under the hood and a mildly used 14 inch pug on the roof.. you can never be too careful:D
#8 viceversa
viceversa
    Subaru Fanatic!
  • 368 posts
  • Virginia
Posted 29 January 2004 - 10:02 PM
the donut gets thrown out on all cars I have.
full size spare replaces it.
I think the logic behind the donut is that it is compact, light, which may accumulate into some savings over the years.
#9 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 29 January 2004 - 10:03 PM
Actually, over a production run of thousands of cars, it equates to a substantial savings for the manufacturer
#10 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 29 January 2004 - 11:25 PM
inflate the spare to the max. pressure stamped on the sidewall
#11 XSNRG
XSNRG
    Elite Master of the Subaru
  • 3,657 posts
  • Olympia
Posted 30 January 2004 - 12:20 AM
I generally inflate tires to the maximun pressure listed on the sidewall but as mentioned, only if the tire is in good condition.
Interesting side note:
I went hiking one day and when I got back to the car at dusk, I discovered I had a flat tire. I pulled the space saver outa the engine bay and it was flat too. I was 20 miles back in the woods and didn't have a coat, no food, nothing. I didn't want to ruin my good flat tire so I bolted on the spare and drove on it determined to get closer to the highway. Anyway, I ended up driving all the way out on it and then another 20 miles, ON THE FREEWAY! at 50MPH. I got home and the sidewalls were damn near worn through but it didn't even break the bead! Them suckas are tough!
BTW-I reinflated it (not to 60PSI!) and it would hold air with a slow leak!
#12 sub87dl
sub87dl
    USMB Regular
  • PipPipPip
  • 31 posts
  • Cleveland, OH
Posted 30 January 2004 - 02:34 AM
Thanks guys for the advice and experience. I'll inflate it to 60psi, since the rubber appears to be in very good condition. I just don't want this thing blowing up in my face at the service station.
But, now that several of you mention a full size wheel will fit under the hood, I'll add that to my shopping list for my next JY trip.
Luke
