5218 replies to this topic
#5151 Frogger-ru
Frogger-ru
    New User
  • PipPip
  • 15 posts
  • Arizona
Posted 09 March 2013 - 12:49 AM
Yes, me is VERY ecstatic!!! :clap: :banana:  Yay, I can drive Barry again!!! Wheeeeeeeee!!! :D Now all he needs is a good washing/wax so I can take some new pics. :D
#5152 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 3,708 posts
  • Hillsdale, Mi. USA
Posted 09 March 2013 - 05:45 PM
Sold it.....
Sold the '85 BRAT GL to tdodge41 today.
Kinda hate to see her go, gut she's going to a good home.
I'm happy with price, he's happy with BRAT and associated parts he got.
All is good.
#5153 jj421
jj421
    USMB is life!
  • 333 posts
  • Sammamish, WA
Posted 09 March 2013 - 07:02 PM
Still in the process of it, but いぜん (Izen) got a new clutch and flywheel. As well as putting in a 5-speed D/R.  :)
#5154 Idasho
Idasho
    Garage Junky
  • 853 posts
  • North ID
Posted 09 March 2013 - 08:48 PM
My GL is officially the garage queen!   :)
I ran across a low mileage '05 Rav I couldnt say no to.  So it will be the wifes DD and our road trip rig.
I finished up with giving the Rav a base-line service just so I know things are up to speed.  Pretty clean little thing.
I think its even SMALLER that the GL  :huh:
Ill have to do a photo-shoot and comparo with these two little 4wds.   They are VERY similar in more ways than you could imagine... Silly little japanese rigs!
#5155 Twitch de la Brat
Twitch de la Brat
    Village Psycho
  • 1,363 posts
  • The Athol of Idaho
Posted 10 March 2013 - 03:26 PM
The only problem with the Rav-4 is that the engine and transmission point the wrong way :P
And the AWD/4WD system isn't as cool as a Subaru's :P
Twitch
PS: Congrats on being able to stash the GL in the garage. Keep it away from the nasty road grime for a while.
Edited by Twitch de la Brat, 10 March 2013 - 03:27 PM.
#5156 Idasho
Idasho
    Garage Junky
  • 853 posts
  • North ID
Posted 10 March 2013 - 04:40 PM
Yes, motor is pointed the wrong way.
But this vintage Rav uses the same type of AWD system that most Subarus do. A viscous coupled center diff controls power distribution front to rear.
Only hang-up is the non- "symmetrical" front axle lengths due to the transfersely mounted engine and trans.  So loss of traction in severe cases it due primarily to torque steer.
Fun little rig though.
#5157 Subruise
Subruise
    Official Party Pooper
  • Gold Subscribers
  • 1,024 posts
  • pierce county
Posted 10 March 2013 - 08:10 PM
changed the fuel pressure regulator and seafoamed the IAC on the loyale. still stumbles....
On a positive note, I learned to resolder EA82 clocks and revived two of those today with my 1950s waller solder gun.
#5158 Twitch de la Brat
Twitch de la Brat
    Village Psycho
  • 1,363 posts
Posted 11 March 2013 - 01:16 AM
Saw this
And after confirming the dreaded with a pull of the dipstick I did this
Now starts the rebuild...
Stay tuned for updates.
Twitch
PS: May get its own build thread if all goes well
#5159 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 25 March 2013 - 12:08 PM
Wedge has developed a jumpy tach and sounds like a WRX. ER27's aren't supposed to sound like that. Noo!!!!
#5160 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 25 March 2013 - 04:35 PM
I was under the car tightening the exhust when I found this:
:huh: I think something's missing...
:o
#5161 JuhaKankkunen
JuhaKankkunen
    Advanced Member
  • PipPipPip
  • 32 posts
  • Argentina
Posted 25 March 2013 - 06:20 PM
Upssssss!
I must do a complete rebuild of my brake system. I'll post some pics. Hope to start next weekend!
#5162 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 28 March 2013 - 05:45 PM
Replaced the Ditsy in Wedge. Power is back, tach is back to it's normal self, no more rough idle, and my hesitation in mid-throttle is gone.
All was good till my return from lunch today when the misfire returned! Idling rough, lower power, and exhaust sounds like it's missing a cylinder every time. The car was mostly warmed up when I shut it down to go get lunch. It sat for about 20 minutes and that misfire showed up right after I started it back up.  I'm gonna look at it again later this evening, but this is going to be a challenge to find the cause since it appears to be temperature related.
At least the jumping tach and the hesitation at part throttle are gone.
Edited by subynut, 28 March 2013 - 05:46 PM.
#5163 Twitch de la Brat
Twitch de la Brat
    Village Psycho
  • 1,363 posts
Posted 31 March 2013 - 01:19 AM
Partially fouled plug finally completely fouled?
Broken spark plug wire?
Bad ground?
Dirty Injectors?
Tired gerbil in the engine?
Twitch
#5164 Lacyjs9
Lacyjs9
    Advanced Member
  • PipPipPip
  • 64 posts
  • Mcleansville NC
Posted 31 March 2013 - 09:40 AM
Went to the beach cv axle went out ate the brake drum hub out so new hub cv axle and wheel bearing
  • Attached File  roo4.htm   186.64K   22 downloads
  • Attached File  roo3.htm   244.36K   10 downloads
  • Attached File  roo.htm   244.87K   8 downloads
  • Attached File  roo2.htm   244.46K   8 downloads
#5165 Sandrion
Sandrion
    Member
  • PipPip
  • 19 posts
  • Grover, North Carolina
Posted 31 March 2013 - 11:12 AM
Changed the plugs, wires disty, and rotor in the Loyale. Dropped the tank, cleaned it out, cleaned out my pump, ran all new fuel lines, installed a see through filter "before" the pump, changed the oil, installed new rear struts, and new front cv axles are on the way.
#5166 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 01 April 2013 - 09:43 AM
Bad ground?
Dirty Injectors?
Twitch
Bad injector. It started acting stupid again about halfway through my arrands. Took it home and started the spark plug trick but I just flat could not find it. So, I got dangerous! I blocked the wheels, set parking brake real good, put it in drive, and redid the test. Ah ha! Cylinder 5 is the problem! Checked spark: ZAP! Ouch. Got spark! Pulled the injector connector and checked the impedence: nothing. Huh. Checked another injector: There's impedence on that one. Bingo. I swapped it with a spare injector I had and no more misfire! Whoo hoo!  Wedge is going on a road trip! :banana: :burnout:  First one in 4 years! :blink:
#5167 l75eya
l75eya
    Subaru Nut
  • 908 posts
  • Hoboken, NJ
Posted 02 April 2013 - 06:53 AM
Made it 150 miles home with a busted rear pass. Axle. My my was that noisy.
#5168 rain_man_rich
rain_man_rich
    USMB Regular
  • PipPipPip
  • 72 posts
  • Grants Pass
Posted 02 April 2013 - 08:24 PM
Replaced distributor cap.  Car was missing badly (every once in a while), idling erratically(every once in a while), and had to crank for up to 10 seconds at start(every once in a while). At its worst when pulling out from a stop the car would either have no power or buck very wildly.   I tried pulling the rotor off but it was stuck on pretty good and I didn't want to mess anything up by pulling harder or using any kind of prying tool.  Is there a set screw or trick of some sort to to remove the distributor rotor?
1990 Loyale
MPFI
Turbo
4EAT
#5169 Legourde_Nux
Legourde_Nux
    Advanced Member
  • PipPipPip
  • 68 posts
  • Santo Domingo, DR
Posted 04 April 2013 - 07:27 PM
Changed radiator to block hose and inner CV boot....considering a skid plate.
1994 Impreza
FWD
EJ16
#5170 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 173 posts
  • Akron
Posted 05 April 2013 - 10:30 AM
1990 Loyale
MPFI
Turbo
4EAT
Yep, has got a small, Philips head screw opposite side (IIRC) of the rotor tip. Using a stuby helps and use a high quality one. Mine was REALLY in there (original), maybe even loc-tited in and you DO NOT want to strip that screw...
Still have the 50+ shimmy/vibration... Thinking it might have to do with the sloppy inner CV (the cup-to-output stub with the roll pin, not the shaft-to-cup).. MUST fix that..
And eying a low mileage EJ20... but since some $)(*#)(% SAT on my hood while parked for a concert in Cleveland, I've now got a slight crease by the driver's headlight.. (Not that the hood was perfect, some dings and stuff, but rust free damnit!) I'm thinking an EJ22 (since I can snag one at the pull-a-part for 150) but with an M62 on top. And that middle part of the hood is in the way.. :D
#5171 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 17 April 2013 - 12:30 AM
:D
Rides much better. The rear now matches the front and the balance feels closer to neutral. 250 lbs/in and currently, I have the dampers set to all the way soft. I have a RallyX Saturday, will see how it handles. :brow:
#5172 Legourde_Nux
Legourde_Nux
    Advanced Member
  • PipPipPip
  • 68 posts
  • Santo Domingo, DR
Posted 17 April 2013 - 10:52 AM
:slobber: .... :headbang:
#5173 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 17 April 2013 - 12:11 PM
Took the PandaWagon through my usual fast corner today and it hugs the road so much better. Turn-in inputs have been greatly reduced.  :banana:  :burnout:
#5174 jonas
jonas
    Subaru Nut
  • 766 posts
  • Oakridge
Posted 20 April 2013 - 04:33 PM
Replaced axle, ordered new (reman) calipers for the brat today. Couldn't get the brake pistons to turn and with the cost of hardware and pads, a nice set of loaded, fresh calipers is just what the doctor ordered! Hope to be back on the road next weekend. While driving the wifes Grand Cherokee to and from work is nice, the Brat is just more fun....
http--,,--//
Edited by jonas, 20 April 2013 - 05:00 PM.
#5175 subynut
subynut
    EJ Powa!
  • 1,292 posts
  • Sierra Vista, AZ
Posted 22 April 2013 - 12:00 AM
Went racing:
Had a blast and the wagon handles much better with the upgraded springs and shocks. :banana:
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
