* * * * * 6 votes
7282 replies to this topic
#5701 jj421
jj421
    USMB is life!
  • 601 posts
  • Auburn, WA
Posted 12 March 2014 - 05:52 AM
Got my Australian corner markers installed. :)
#5702 motorrad2
motorrad2
    Member
  • PipPip
  • 13 posts
  • Boise, ID
Posted 13 March 2014 - 02:27 AM
Finding coil springs for a Loyale 4wd wagon has been a challenge. I have repeatedly gone back to the "BumbleBeast" thread, but I'm not looking for 2" lift. I wanted a firmer ride for sportier handling and a slight ride height increase for looks, I don't want to stress my CV joints, and I want to know spring rates!!
So I purchased a set of NAPA coils springs for a 2004 Camry. Spring rate went from 146 stock (who knows what they are 21 years later) to 162. Spring ends are flat and tangential, not exactly like stock, but they fit up just fine. ID is almost equivalent, length is about .5" longer, wire diameter is thicker.
I just installed sealed front wheel bearings because greasing the inner sets are a pain.
Replaced valve cover gaskets.
New drilled and slotted black-zinc brake discs with ceramic pads, on their way to me right now.
Rear springs and shocks are next. The NAPA salesman was oh-so-kind to give me a coil spring catalog, and I found a Monroe fitment catalog online in pdf format. I'll post a follow-up to the rear setup.
Would like to have a set of white spoke wheels to powder-coat and mount with new tires that will be necessary this summer. I have two 1980-84 types and two 1985-1989 types, would like to find two more of the later style.
Update: ordered a pair of KYB GR-2 ( p/n 341065) shocks for the rear. Look great, DON'T FIT!!! They are about an inch shorter than the old shocks, and no way can I get the assorted bumpers,washers,frame mount, and spring seat on the piston shaft and still spin the nut. The old shocks from the car have only a "733331" stamp, no manufacturer's name, but I found a Gabriel catalog which cross-references a 733331 MFG number to a Gabriel Part Number....... G51183. I just ordered a set for $74 from my local O'Reilly's and will have them tomorrow morning. Spread the news!!!!!! Gabriel G51183 !!!!! Direct-fit replacement shock for the 4WD Loyale wagon !!!!
Moog CC248 coil springs will be mounted in the rear, purchased off of ebay for $53.
Decided to rebuild the front brake calipers, but found brand-new calipers from R1 Concepts for $120 (set of right/left), so I bought them!
Edited by motorrad2, 21 March 2014 - 06:00 PM.
#5703 81EA81
81EA81
    Eat, Live, Breath Subaru
  • 387 posts
  • Spokane,WA
Posted 13 March 2014 - 01:47 PM
Just takin the piss mate!
#5704 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 13 March 2014 - 07:09 PM
Finding coil springs for a Loyale 4wd wagon has been a challenge. I have repeatedly gone back to the "BumbleBeast" thread, but I'm not looking for 2" lift. I wanted a firmer ride for sportier handling and a slight ride height increase for looks ... I purchased a set of NAPA coils springs for a 2004 Camry. ....
So, the Toyota Camry coil springs you obtained, are for the Front, isn't it?
Could you post Photos of them, side by side with the Subaru ones?
Also, I'll love to know the Results. Thank you for sharing the info,
I bet it will be Useful for more members.
Kind Regards.
#5705 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 16 March 2014 - 08:57 PM
Just cleaned the Weber air filter, used the K&N cleaning kit. Made a big difference in how it drives too. Also recently got a tank of straight non-ethanol gas and the valves are MUCH quieter. Found a place to put my tank vent line too, I did have it plugged and the fuel system was building up extreme pressure. It would get so bad that the pressure was causing it to run rich which would cause it to run warmer than usual, and I'd have to pull over and relieve pressure by cracking the gas cap. That usually resulted in being soaked with gasoline, so I'm really glad that problem is solved.
#5706 RustyBrat
RustyBrat
    Subaru Nut
  • 749 posts
  • Pocatello Idaho
Posted 16 March 2014 - 09:18 PM
just finished paint
8228cc0b0bd4a9eec2493421d8befb9c_zps7da4
#5707 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,955 posts
  • Texas
Posted 16 March 2014 - 11:45 PM
06 WRX steering was vibrating (but no squealing). Foam in the reservoir - just like my 03 OBW. So, pulled the fitting off the top of the PS pump and swapped out the o-ring. The closest one I had may not last long, had to stretch it a bit and I am concerned it isn't 'fat' enough now. But I ordered a larger assortment set from ebay so, i should have those on hand if it fails again.
Probably do maintenance type stuff in april on both cars. WRX is needing a timing belt according to the Months side of the schedule. i think I'll put that off till october.
Edited by 1 Lucky Texan, 16 March 2014 - 11:47 PM.
#5708 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 7,528 posts
  • Roatán, Honduras.
Posted 17 March 2014 - 12:58 AM
... Found a place to put my tank vent line too, I did have it plugged and the fuel system was building up extreme pressure...
Where did you put it?
I left open, the one on my Subie, for the same Pressure Buildup.
Kind Regards.
#5709 Captin Hook
Captin Hook
    New User
  • PipPipPip
  • 78 posts
  • Spokane
Posted 17 March 2014 - 07:06 PM
Got the wheels I got off of Qman ( thanks again) put on.
#5710 jonas
jonas
    Subaru Nut
  • 1,209 posts
  • Oakridge
Posted 17 March 2014 - 07:14 PM
Kind Regards.
I would like to know this as well.
#5711 Rlmcowboy
Rlmcowboy
    Advanced Member
  • PipPipPip
  • 41 posts
  • West Middletown Ohio
Posted 17 March 2014 - 07:44 PM
Fabricated new rear bumper for the GL. Front will be next.Attached File  image.jpg   122.49K   70 downloadsAttached File  image.jpg   71.87K   60 downloads
#5712 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 17 March 2014 - 09:53 PM
I'll have to take pics, it's kind of hard to explain. I do know that there's a total of three lines coming off of the fuel filter and one goes to the carb, one comes from the firewall and the other goes back into the firewall. And between the two that are going/coming into/from the firewall T into eachother. Freakin weird.
#5713 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 7,528 posts
  • Roatán, Honduras.
Posted 18 March 2014 - 01:39 AM
... I do know that there's a total of three lines coming off ...
Yes:
The 5/16" Main line is the "Fuel Delivery" to the Carburator.
The 1/4" Secondary Line is the "Fuel Return" to the Gas Tank.
The 3/16" Third line is the Gas Tank's "Vent Line"
I only hooked the main to the carb, closed the return and left the vent line open, but I attached one of those mini air filters to it, in order to prevent debris to get into it; those two unused lines hangs next to the Brake's Booster, hiding there and the Subie has been working Flawlessly like that for many years so far...
Hooking a "T" between the Return and the Vent Lines, will cycle the pressure buildup on the Pipes / Hoses and in my own humble opinion, could be Dangerous during hot weather days, and high pressure buildup on the system.
But please, post the Photos... maybe I'm wrong and misunderstood the setup.
Kind Regards.
#5714 rrgrr
rrgrr
    Subaru Fanatic!
  • 439 posts
  • Bloomington
Posted 18 March 2014 - 08:34 AM
Fabricated new rear bumper for the GL. Front will be next.attachicon.gifimage.jpgattachicon.gifimage.jpg
That is a Really Nice Work!!  :headbang:
#5715 Rlmcowboy
Rlmcowboy
    Advanced Member
  • PipPipPip
  • 41 posts
Posted 18 March 2014 - 08:58 AM
Thanks rrgrr. Plan on getting some paint on it tonight and bolted on.
#5716 Rlmcowboy
Rlmcowboy
    Advanced Member
  • PipPipPip
  • 41 posts
Posted 18 March 2014 - 08:10 PM
All done.Attached File  image.jpg   146.05K   49 downloads
#5717 MR_Loyale
MR_Loyale
    22 Years of Ownership. 94-16
  • 1,526 posts
  • Seattle
Posted 19 March 2014 - 11:11 AM
Last weekend I turned the adjustment nut on the hill-holder cable because the hill-holder wasn't engaging. That and the clutch adjuster nut were loose. Tightened them both and it all works now. Time for a nap.
Edited by MR_Loyale, 19 March 2014 - 11:14 AM.
#5718 chompy
chompy
    Member
  • PipPip
  • 27 posts
  • Portland
Posted 19 March 2014 - 07:49 PM
Put a weber on my 84 GL Wagon last weekend.  Removed a pile of unused vacuum system throughout the process.  Sorry huge image...
Used the air filter from the air valve for the tank vents for now.  It had fallen apart to reveal the paper filter.  It's attached to the two vent lines at the moment.  In the future I'll replace it with a proper air filter.  Today I found a muffler at the picknpull for $13 and swapped my rusted open tin can of a muffler out.  Funny how much it muffled the awesome sound the weber can bring out of these engines...  oh well
Next I have to fix my hood hinge which has apparently been gathering water and somehow the bolts rusted out, popping the bracket out completely.
#5719 SmashedGlass
SmashedGlass
  • 669 posts
  • From CO, stuck in FL
Posted 20 March 2014 - 09:31 AM
While re-doing some wiring in the center console and tidying things up, managed to nick a vacuum line when clipping off excess zip-tie  :angry:
*psssssssssssssssssssssssss.................*
Wrapped the cut with aluminum flashing tape and it seems to have sealed it, we'll see in the long run. If it doesn't, I'm not looking forward to pulling the cluster
to run heat-shrink tubing down that line.
#5720 rrgrr
rrgrr
    Subaru Fanatic!
  • 439 posts
  • Bloomington
Posted 21 March 2014 - 07:25 AM
Fresh Paint! :)
Got a cheapie rack for the spare -Oh ya -getting about 28 mpg!
Edited by rrgrr, 21 March 2014 - 07:31 AM.
#5721 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 21 March 2014 - 02:06 PM
Fresh Paint! :)
Your pic through me off, your car looks just like mine with the new wheel/tire setup I have and almost the same color, definitely did a double take! Looks sharp!
#5722 jonas
jonas
    Subaru Nut
  • 1,209 posts
  • Oakridge
Posted 21 March 2014 - 08:15 PM
http--,,--//
Guess what i did to the wagon today.
#5723 987687
987687
    Rally Suby!
  • 4,262 posts
  • Northern Maine
Posted 22 March 2014 - 08:42 AM
Ughhhh I've gotta do that. My header is cracked and leaks. I'm probably gonna have to cut a section out and weld in some new pipe.
#5724 bratman18
bratman18
    ADIDASubarus
  • 3,863 posts
  • Jefferson, Maine
Posted 22 March 2014 - 08:48 AM
I have 2 Loyale y pipes, which is what is on your GL. I have nothing to use them on so let me know if you are interested in one.
#5725 987687
987687
    Rally Suby!
  • 4,262 posts
  • Northern Maine
Posted 22 March 2014 - 09:14 AM
Oh yea! I forgot you had those. I'm gonna do a bit of a refit on the car this summer. I need to do suspension, bushings, fix a bunch of oil leaks, etc. So I'll probably take you up on that offer.
For now, since the outback works again the GL is taking a break until summer vacation starts. I forgot how nice it is to drive a newer car lol.
