EA82 Dual Port Heads
5 replies to this topic
#1 RenaissanceMan
RenaissanceMan
    Why am I here?
  • 706 posts
  • Eugene, OR
Posted 29 January 2004 - 06:01 PM
Hey I got a quick question out there for all you EA82 Guru's, Can I take a MPFI head, and put on the oil passage lines and use it with a turbo with little effort? What all is needed to change over, or am I going to have to drill holes in it or something? The junkyards here seem to have quite a few MPFI engines at the moment, and all the turbo's are crapped out. I figure the mpfi heads probably have had less abuse as well
Thanks everyone!
#2 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 29 January 2004 - 07:35 PM
I have wondered that myself.
#3 ccrinc
ccrinc
    The Subaru Whisperer
  • 1,027 posts
  • Denver, CO
Posted 29 January 2004 - 08:56 PM
Yep, the casting is the same.
First priority is to put turbo exhaust valves in it!
Then depending on which side you need, complete the conversion. If you have them (MPFI & Turbo) side by side, you should be able to see what needs to be done.
Emily
http://www.ccrengines.com
#4 RenaissanceMan
RenaissanceMan
    Why am I here?
  • 706 posts
  • Eugene, OR
Posted 30 January 2004 - 02:45 AM
Thanks Emily... just curious, why would I want to change the exhaust valve? What is different about it? I think I have a pile of them lying around here somewhere anyway from previous engines..
Anyone else have any input?
#5 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 30 January 2004 - 03:28 AM
I don't remember the specs from the FSM, but the turbo exhaust valves are thicker in order to better handle the higher temperatures of the turbo motor.
#6 ccrinc
ccrinc
  • 1,027 posts
  • Denver, CO
Posted 30 January 2004 - 08:33 PM
What Snowman said. :D
Emily
