Change the water pump. If the T belt is due might as well do it with new idlers.
When filling the car start with coolant in the upper radiator hose. Then the radiator.
With our t stats on the bottom of the block, you will never fill it by just adding to the radiator.
O.
https://www.ultimatesubaru.org/forum/topic/168698-rear-wheel-bearings-ring-nut-tool/
IF the outer CV cup is stuck on the stub axle, there is a way to get it loose without destroying the CV.
You'll need access to a 20 ton hydraulic press with stout press plates & a large clamshell bearing separator.
Wait a bit & I'll get a 'How-To" post up.
Here ya go...
https://www.ultimatesubaru.org/forum/topic/168762-saving-rust-seized-ea-rear-axle-stubs-cvs/
There should be a roll pin through the axel, holding it onto the stub. The axle stub has tapered roller bearings, held in by a special nut on the backside of the bearing housing. There are a couple of threads with details of the wrench, etc.
Try wrapping some electrician-tape around the mating surface on the latch-loop (the steel-loop attached to the sill of the trunk).
No too much tape, or else the latch won't work. Just a wrap or two can cure rattling a hatch-back.
Nah keep the original axles. The originals are robust and can last the life of the car if regreased and rebooted. New axles such decaying trash. Problems all the time.
Timing pulleys replace at regular intervals. They’re ancient and lack grease and will strand you if they fail. I use a needle fitting and pump them with new grease in XT6s where pulleys aren’t available , if you can’t get parts.
