Everything posted by remarcable
Many tranny problems like this can be solved by a flush of the transmission system. Find a place that can do the flush either with a fancy machine (best choice) or by simply detaching the ATF return line from the radiator and pouring new fluid in while the old pumps out. You can drop the pan yourself and change the external filter (if your car has one) but that will still leave several quarts in the torque convertor. $100 for a flush is alot cheaper than a new transmission.
I love my subaru and have decided to stick with it until it falls apart. I came this close to buying a miata and selling the outback, but I got a Dodge GC van loaned to me while the outback gets worked on. The outback handles like a go cart compared to the horrible handling characteristics of a top heavy FWD american made minivan. On the list at 56K miles (99 outback) - front and rear brake pads - Struts+Springs all 4 corners - brake rotors front and rear - Water pump (weeping currently) - Thermostat - Timing Belt - LEAKY HEADGASKET -"funk" odor in cabin must be eliminated - bald tires need replacing but can wait All in all this will cost me around $2000 assuming I install everything myself and the dealer decides to not honor the 60k mile warranty. If the dealer repairs the headgasket under warranty I'll have a cool grand left to spend on bushings and swaybar mounts and stuff like that. I really should not have to drop 2 grand into a vehicle with only 56k miles on it. On the upside, my transmission is working great and my engine is squeaky clean (coolant tends to do that). I have stopped suggesting people buy Subarus with the 2.5 engine. I make sure to specify 2.2 liter turbo when making car suggestions.
I was the one who posted photos in the old thread and had the same thing happen to my 99 outback. My experience is in that thread and you can save the images there and use them at your discretion. I think I may still have the old broken part of the bar somewhere if you need it for a lawsuit or anything. I went to Dale Teague http://www.boxer4racing.com and he found me a front sway bar from a junked legacy outback for around $60 I think. I replaced the front swaybar without removing the exhaust, and it was a pain in the rump roast. Worse than those 50,000 piece 3d puzzles. It only took me about an hour to do it, even with my troubles getting the bar in place. You might want to look into getting an aftermarket swaybar in an upgraded size for better handling and turn-in performance. Get the urethane bushing and heavy duty endlinks/mounts for an even better (but slightly harsher) ride. I did not go to a Subaru Dealer because I despise the local one and would rather deal with it myself even if it means paying out of pocket. The outback has also seem some rough terrain and I'm sure I'd get the 'abuse' riot act read to me at the dealer.
I still have a Primitive Racing 1/8" skid plate on my 99 outback and it has survived quite a beating. If you offroad your subie, you need something similar. It's actually pretty nice on the road too, because the engine bay stays cleaner. I've even encountered a hydroplane effect when hitting deep puddles instead of the bog-down-and-break-something-going-under-water that usually happens. Get a skid plate! For convenience I suggest one with a hole cut out near the oil pan drain bolt.
This is quite common. Nobody will pay as much attention to working on your car as yourself, and I now do all my oil changes that I can myself. I once found over 6 quarts of oil in my subie after a dealer visit, which is strange because I only gave them 5 quarts to put in, yet when I drained it all it overflowed out of my 6 quart catch pan. It also wasn't the Mobil 1 I had given them to put in. Something as simple as an oil change I suggest doing yourself. For warranty purposes you should keep the receipt for the oil & filter and mark the mileage on the receipt.
When I replaced my outback's stereo the wiring diagram in the haynes was completely wrong. I found an old SVX wiring diagram and that was spot-on for the speakers, but the power and other wires were guess and go, although a voltmeter did help. Nowadays I hear they have these things called wiring harness adaptors which was apparently non-existant in 1999 for a 1999 subaru.
I'll just take it to the dealer. ... with the following precautions: A) My tires are marked so I'll know when they put them on wrong. Last time they couldn't quite figure out which direction the directional tread went and put two on backwards. all my parts have my initials etched in them so I will know they used the parts I supplied, since I have had problems with this in the past. C) I'm supplying all my own parts and fluids, and will ask to have all old parts and empty fluid containers back. I always use Mobil 1 and always give them 6 quarts in case they spill some. Last time the car came back with dinosaur oil in it and no mobil 1 anywhere to be found. They claimed I never brought it in. Am I being an *******? I just want things done properly... I hope it isn't too much to ask.
The subject line says it all. I'm trying to avoid having my subaru serviced by the local dealership due to bad previous experiences with them. 1999 Legacy 56k mi., w/ leaky headgaskets. My mechanic I usually go to says he needs someone to contact about the warranty, usually an 800 number or bundle of paperwork or something. Also... is it wise to have someone other than subaru do the headgaskets as long as I get them the correct revision subaru gasket? I'm also have the water pump, timing belt, and thermostat (and seals) done and the local mechanic's labor cost will end up being about $350 cheaper than the dealer's cost.
The outback is handicapped in the handling and performance department by the extra weight, tire/rim choice, and tall suspension. If you want to lower it you will need to go to a different size rim/tire to avoid hitting the struts. You should actually try and find a Legacy GT Wagon of similar model year. It will handle better and be more receptive to upgrades if you can find them. It seems like the aftermarket for our 2nd gen legacies has really died down a bit. If you want to go up a stage in performance but down a stage in comfort, try the impreza platform which includes the forester. There aren't huge performance gaps between the legacy/impreza of that model year but if I were to pick a 1996 model year to turn into a rally car I'd go with an impreza.
I heard awhile back on this board and others that a Rental place was running subarus in FWD during the summers to cut down on gas costs. No ill effects were reported on the cars. I can't confirm those reports, so it could be fiction. I think the owner's manual warns about impending doom regarding using the donut spare. I'm not sure it said anything about using the FWD fuse with 4 perfect tires. I also seem to remember a guy named Kevin who had a beefed up impreza sport which he drag raced and used FWD mode on the dyno to calculate horsepower. I'm not sure if that would even work since the rear axle is still attached to the front, just not receiving power.... correct? It is still dragging even when in FWD mode. In regards to draining the 4 quarts in the ATF pan, that doesn't do a whole lot if you are having serious fluid problems. The best thing to do is a flush which gets the 8 quarts left in the torque convertor. You should always do a flush when switching to synthetic or back to regular for best results. I personally would avoid mixing synth ATF and regular ATF.
I'm almost certain it is headgasket failure now. I've posted a previous thread about this trying to narrow the problem down because I hadn't seen any of the normal headgasket signs. Today I put in a new battery, new EGR valve, and new rear brakes (hey, why not?) and I am still having problems with the car almost stalling at idle and fluctuating/abnormal idle. I realized that I had been driving the car like grandma since it started having problems, and that I hadn't really beaten on it for a long time, so off I went. Overdrive is for weenies. Real men go 70 in 3rd. Well, real men with automatic transmissions anyway. The car drove as beautifully as a 99 Subaru Outback with bald summer tires and failing suspension can drive. I noticed no problems or hesitation, in fact the transmission was responding as good as it did when the car was brand new. I hadn't driven it like this since I had it flushed 3 months ago. After winding (bored push up/ push down would be more accurate than "winding") through all of the (3) gears and generally driving like I was at an autocross for an hour, I headed back home to the garage. I popped the hood and checked the overflow reservoir's volume - it had raised a half inch and was above the full mark. I opened it and couldn't see the fluid. I shined a light in and realized I couldn't see the fluid due to the cloud of vapor rising from within. I blew on it and cleared the air, so to speak, then I noticed many bubbles (1-2 per second) coming up through the coolant, which was no longer quite as green as it should be. More visible vapors were rising from the coolant. It looked like steam. I tried smelling for gas/oil but I have a cold and can't smell anything. I'd take it to the dealer tomorrow but I'm still waiting on a parts order from 1stsubaruparts.com with all the items they will need to do the repair and other important 60k things (water pump, thermo, timing belt, etc). I hope I can get it in before christmas, and I hope I get it back in running condition. The last two times it has been to the dealer it has come back with new gremlins and problems I've had to resolve myself. I don't like the local dealership one bit, but I'm still under 60k miles and it's ridiculous for a headgasket to fail so soon. I'd like to thank Alias### (forgot your numbers) and everyone else who helped me out with suggestions and tips in the other thread. This is a great forum and I'm honored to still be a moderator here after all these years. PS- New suspension goes on as soon as the engine is fixed! I'll post pics. :wave:
I had the same thing happen but higher up on the arm. The blade assembly fell off at 70MPH in a downpour. I am very glad I had applied Rain X to the windshield or I would not have been able to drive. The windshield got gouged from the wiper-less arm scraping. Now I replace the blade assembly every 3 months and check the integrity of the rest of the arm too, including tightening those bolts that like to work loose over time. They have to deal with alot of corrosion and movement, so it is no wonder they fail. Loctite anyone?
I have yet to take the car to a mechanic, however I have ordered the following parts: -Water pump + gasket -Timing Belt -Thermostat + gasket -new struts and springs (yay!) -new rear brakes -new bulbs all around My theory on the noises: -Droning at idle and probably while driving *Failing water pump possibly from headgasket failure, possibly normal wear. -High pressure hiss sound that continues when the car is turned off (sometimes for up to several minutes) *Air trapped in coolant system OR coolant being sprayed into engine As soon as I get the parts in from 1stsubaruparts.com (good prices, good service) I'll be taking it to a local mechanic to get the timing belt, water pump, and thermostat replaced. I didn't order a new tensioner because I'm hoping the old one will still be fine at 56k miles. I have examined the coolant and it smells like coolant. I can't smell any gasoline or combustion-related odors in the overflow tank, and I have never seen bubbles in the overflow tank even after 'spirited' driving. Even if my headgaskets are OK, should I still expect to have them fail? Should I order the latest revision headgasket and have it installed as a preventative measure? I'm going to read up on procedures in my Haynes manual and check out a few things like the AIC, PCV, and whatever else isn't too in-depth for tonight. I might even take pictures if I have questions. Thanks for all the assistance! EDIT- PCV valve checks fine, but the EGR doesn't move as freely as I think it should. It isn't seized, but the movement isn't smooth and requires some force.
We rarely if ever see snow here, but I've gone through several sets of outback sized tires looking for something that handles moderatly well. I couldn't. I finally switched to 16" rims and went with Dunlop SP 5000 z rated high performance all seasons. They wear quick, but remain nice and sticky even on cold days. I won't be buying them again because of the cost, but they were very fun tires on dirt roads and wet pavement alike. The XW4s and Rainforce/X-One tires all had hideous sidewall rollover upon cornering and were very unpredictable when pushed to their relatively low limits. If you see snow I highly suggest investing in a spare set of rims with snow tires on them and a jack. All season tires are a compromise and really are not great in the snow. Get snow tires! EDIT- I forgot to mention the dunlop sp's have about 12,000 miles on them and are bald on the outer and inner edges. Scooby skating ahoy! I'll need new rubber by spring, but I think the added drivability and fun the tires provided were worth the short life and high cost.
If you are buying an Outback and cannot afford a 2001 or newer, the 99 would be my choice. It has the most bug fixes of that generation platform. Stay away from the 2000 model unless you plan to invest in a big brake kit as the brakes are *barely* adequate for the car's weight. Just make sure that like any used car purchase, you check out the vehicle's history on carfax (or other methods) and talk to the owner as much as possible about the car. Ask what kind of oil they used for oil changes, or did they take it to Jiffy Lube for service? Was it dealer serviced? Are there records to show this? Has the timing belt been changed? I believe you can go as long as 80k miles on the t-belt but I am changing mine (along with water pump and thermostat) before 60k miles. Are all four tires the same brand and model? Does the tire wear look even? Crawl under the vehicle. Look for corrosion, rust, and evidence the vehicle has been used offroad. You really want to find one that hasn't been in a lot of snow or mud. Ideally snag a former soccer mom or grandma's ride which has only had 1 owner and been garage parked the entire time. Check the oil and all fluids for proper level and condition. The subaru owner's manual that came with the car is actually pretty good about explaining how to do all the basic stuff like checking the oil. It doesn't go very in depth beyond saying "If it doesn't meet spec take it to a dealer" but I have found the owner's manual handy. Look for it in the glove box. I don't really like the subaru synthetic leather seats and have cloth in mine. Go try out a few and see which you like the best, the texture of the seats is a personal choice. You can always buy some used WRX seats ($400) and install them since the bolt pattern should be identical.
Does anyone know of an online vendor where I can order replacement urethane bushings and parts for my 99 outback? I'm looking to replace all the rubber bushings on the swaybars, endlinks, etc. I found some Perrin Rear end links for $140 from Teague's, but they don't have any other parts listed. All mine are shot and I don't want to replace them with more rubber bushings that willl degrade just as quickly. -Front/Rear reinforced/ugpraded endlinks -Front/Rear heavy duty swaybar mounts -Urethane bushings for front and rear sway bars I wouldn't mind picking up a 22 or 24mm front swaybar, but I can't find those either. They were everywhere I looked when I first got the car.
I wore rubber gloves and hammered a screwdriver in the filter to turn it. It wasn't too horribly bad. Not anywhere near the nightmare of getting an oil filter off a mazda 626 when it was put on there by a 6000 pound gorilla. This is not the approved factory method and will certainly void the warranty on the filter you are removing.
This is a little bit of thread necromancy, but I just found these on my old digital camera. Seeing as how my experience is identical to the original poster's, I thought I would reply with the pictures. Mine went with a BANG! as it hit the 1/8" aluminum skidplate covering my engine bay. I thought a tire had exploded at first. This is where my front swaybar on the 99 outback snapped when going over some rough pavement at speeds under 15mph. My entire suspension has sustained increased wear from offroad excursions so I wasn't too surprised. That's also why I didn't make a warranty claim. You are looking at the driver's side of the swaybar. In the second picture I propped the broken part there to get it in the shot. I removed the broken part and drove around (slowly) like that for two weeks until I could locate a used front swaybar ($50). The swaybar in question had less than 50k miles on it at the time and no visible damage that could have caused the break (no chips or dents from impacts - I have a sturdy skidplate). I might still have the broken end somewhere in the garage if anybody wants better pictures.
