Everything posted by mattocs
I put a new connector on the ground wire and connected it...the horn and CC still do not work. The new switch is a bit different from my old one...there are 2 connectors, and the ground. The one that I pulled out of my car only had the one connector, and the ground. The paper that came with the cruise control stuff said the one plug was the OE Horn something-or-other...but there is no place for it to connect to. If it was the switch then the CC should at least work now, right? Or since the horn isn't working...does that mean that it isn't connected properly and that could have something to do with the new switch not working?
There is a ground...it may not be hooked up..would this cause the horn and CC not to work? I installed a new pump for the cruise control system...and the throttle part. I installed a new button on the dash that lights up AND new switch on the wheel...but the ground may not be hooked up...could that cause it not to work?
OK, I installed a new switch in the steering wheel, brake thinger, throttle thing, vacuum pump, button on the dash, and main computer thing...and my CC still does not work. The only thing left to do is the clutch button thing. I don't think its that...I don't know what it is. I hope I installed the switch in the steering wheel wrong...because now my horn does not work. I don't know what else to do. When I press the button, the light comes on, and I hear the 'click' sound from the main cruise control computer thing...but when I go to set a speed or accelerate...nothing. Any ideas?
Yeah, I was assuming thats who you were when I saw your user name (well, one of the Taggarts.)
I am from Slippery Rock, too! Good to see some more local people joining the board. I drive a dark blue Outback with a dent on the hood. You may have seen it around town.
...to take my steeting wheel apart on my 96 Outback. I stipped the torx/allen wrench screw thinger on the righthand side of my steering wheel. I need to put a new cruise control leaver in. So, to get the screw/bolt out I need a lefthand thread bolt or screw... I need a 1/4, 5/16, and a 3/8 bolt/screw. It can be any length, and can be a hex bolt, phillips screw, etc. I am going to screw the lefthead thread screw in counter-clockwise until it is tight, and then it will force the bolt/screw in my steering wheel out by turning it loose. I checked local hardware stores, Auto Zone, Adv. Auto Parts, Lowes, and Home Depot...some have the nuts for the bolts...but nothing else. If anyone knows where I could get one...a store, or a website, or ANYTHING...i'd really really appreciate it. (I tried those things that are supposed to take out stripped screws, the ones that look like weird drill bits... it didn't work)
My truck at work has a bell when I don't have my seatbelt on (I hear it when I am driving across the parking lot at like 5MPH...thats the only time I don't wear it) Buckle the seatbelt, then sit in the seat. Have it behind you. Orrr...get a spare buckle to put in the thinger so it thinks you have it on.
Gas Mileage
mattocs replied to timn29's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
differnet engine...but 1996 OBW 2.2l Average is about 24.4 Worst was around 18 (my MAF was messed up) Best ever was all highway at around 55MPH - 30.5
