Sti ATV!!! the name says it all!!!
or a wheelie in reverse
The ANTI-Gas mileage thread
98 gt replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdone it before on a bet that is i think i drank in the range of about 12-14 glasses about 12 oz each with no ice then ate dinner. (a very small dinner)
98 gt replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdrinks might be 1.50 at a restaurant, but you get free re-fills....
98 Outback
98 gt replied to iathon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear seal leak
Throttle body spacers...
98 gt replied to JEGIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdbl post
Alloy wheel lug nut torque specs
98 gt replied to SWICKEHAM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe will either twist a bit or break when you have applied too much torque. different color= different torque specs.
98 gt replied to JEGIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrom working on hondas the integra gsr has an intake manifold that has a butterfly valve for each runner to the head. one runner is short while the other is a bit longer. this is for maximizing performance and economy on both ends of the power band. it helps the 1.8 deliver better economy in the low rpm range using the longer runner and more power in the higher rpm range using the short runner. these valves open and close due to the vacuum the engine will be pulling on the actuater so in short, yes the length of the runner can have an effect on the economy and power of an engine will try to find a cut away pic of it here in a few minutes or so.
98 overheating
98 gt replied to sprite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXexact same thing happened to me i bought the car then, about 3 weeks after owning it (driving from charleston s.c. to charlotte n.c. about 230 miles and several overheat breaks) i finally had time to get it checked out. it turned out to be a cracked cylinder. so i inquired about repairs and they gave me some bogus amount... so i bought a complete second engine and changed for a new gasket on it before i replaced it in my 98 gt... (along with waterpump and oil pump and thermostat) now engine runs fine no problems whatsoever and this fix cost about 1000 all said and done, doing my own labor. car now has 200k miles and an engine with half that. body looks like it has about 20-30k and same with interior. all said and done happier i did it myself and saved about $500 (to pay for at the time 2.50/gal gas and that was for regular!!!!)
My First Subaru
98 gt replied to Irish1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlooks pretty good, i like the color, could use some different wheels though... but it looks nice to say the least.
98 gt
