e4620
Everything posted by e4620
headlights
e4620 replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
On mine there were four clips, but the lens had a sealant around the edges which made it pretty much impossible to seperate from the body. Why do you need to remove it though? -
I know this sounds stupid, but when I got mine off the lot the rear hatch was stuck also. Turns out they threw the floor mats in the trunk and it got wedged in there. Simple enough to fix. As for access to the latch mechanism, the inner pannel will come off fairly easily, theres six little plastic things on the bottom, pull the cover off each then they slide out. The top is held in with snaps. The mechanism itself is a little bit tricky to get at, the metal panel of the door kind of blocks access. Hope this helps a little.
Well, for just a CB you could power it off the wires to the accessory socket, get some of those vampire clips if you don't want to solder. Just dont transmit and use something else that drains a lot of current in the socket at the same time. CB's don't take too much power, so it should be ok. Just wire an inline fuse on the radio to be sure. But you're probly gonna get noise in the background from the alternator, kind of like a high pitched whine. Just do not use the accessory wireing for anything bigger, like a ham radio.
Well, I'm not sure about an ignition switch, but I've swapped tumblers over in a door lock. It just takes a few minutes really. Imagine my suprise last year when I went to unlock the door and the key did a 360 yet nothing happened:drunk:. Once the old switch is out it may be worth taking a look at on the bench, just don't mess with the new(er) one unless you're sure you can dissassemble and reassemble it.
Would anyone happen to have the wireing diagram or at least pinout for a 1999 legacy(outback, not that that part matters) dash cluster? I went out to just buy a chiltons manual for this but I cant find anything on a 99 yet. Any help would be appreciated, but this is no rush....nothing is broken at least:rolleyes:
warming up?
e4620 replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I can relate to that emergency responder 'get up and go' stuff, but my old '90 legacy didnt seem to mind too much. The new (to me) 99OBW takes it well too, its just kind of annoying to get to the firehouse at 3:00 in the morning for a false alarm just to turn around and go home again....or worse yet get a first aid call for someone with stomach pain because they didn't eat dinner:banghead: I do admit though, giving it an extra few minutes in the morning before I begin my commute is worth it, well..heat is nice at least:cool: -
Diodes scary? Nah, think of them as a one way street, it just lets the electricity go one way. Well...and drops the voltage a little tiny bit, but forget about that for now. And transistors? Basicly think of them as a switched diode......now...large scale integrated circuits:drunk:thats the fun one:banghead: Anyway, if anyone decides to make a circuit to control this thing lemme know, I can probly provide some assistance. If I drove an auto I'd be out there right now working on it.
