233
Posts posted by Loyale 2.7 Turbo
On 11/22/2023 at 7:38 PM, Turbone said:
... From the way it was running before the boost leak, this engine is going to rock!
Cant wait to finish breaking it in, then I can do the fuel mods and slap the VF39 turbo on
Your Coupe is really Awesome! ... Glad to see you around here.
Greetings from Honduras, Kind Regards.
18 hours ago, el_freddo said:
Well this one is probably long gone since the thread is over 7 years old!
These days there’s loads more info and ease in converting these L series to NA EJ or go all out with a turbo EJ conversion.
If you’re really keen on the old unreliable EA82 turbo you’d need to search high and low for a complete vehicle, or go about collecting the parts to make it happen.
The EJ22 is about the same as the EA82t peak power without the complexity and added unreliability of the turbo on the EA82.
Cheers
Bennie
I Agree completely.
As time passed by, the EJ conversion is the most reliable & cheap way to go,
if you want / need to swap engines...
Kind Regards.
On 8/6/2022 at 8:16 PM, 6 Star said:
Awesome!
I subscribed to your channel.
The EA82 in the BumbleBeast still sounds very healthy.
Thank You! ... it still is running Strong and smooth at the same time, no noisy lifters anymore,
at least for this more than a year since the modified lifters were installed.
Kind Regards.
On 1/28/2023 at 8:01 PM, Loyale 2.7 Turbo said:
... Question: as far as I know, the two Timing Chains on this 4 cylinder, GDi 2.4L (G4KJ) "Theta II" engine, are intended to be used during the engine's Lifetime, theres the main timing chain and a smaller one for the oil pump; However, local mechanics has emblazoned the idea of changing them, along their tensioners and related paraphernalia, somewhere around the 100 K or 150 K miles, depending on age and usage. The user manual is not clear regarding the subject.
So, what is the best interval to servicing the Timing Chains on these engines? ...I already obtained the complete Timing Kit but I decided to don't change it yet on this Sorento, until it starts to make noise or until the engine needs servicing. So, I will store the Timing kit for the THETA II 2.4 GDi engine for this USDM 2012 Sorento, untill it could be needed; however I will share here a photo showing the part numbers for each component, as it might be useful in case of someone seeking for such information online:
Thanks God the modified Sorento keeps going strong as a Champ.
Kind Regards.- 1
Another remote possibility is, that the car is using mismatched tyre sizes, side by side...
...or a broken coil spring / shock absorber somehow.
You better do a closer inspection of the suspension on each side, comparing parts.
Kind Regards.
On 9/10/2023 at 9:01 PM, sarco2000 said:
... great write-ups by Loyale 2.7 T are still helping people ... Thanks!
You're Welcome!
Thank you for Lettin' me know.
Greetings from Honduras.
Welcome fellow from Costa-Rica,
Greetings from Honduras...
On 4/4/2023 at 2:11 PM, Costa_Rica_Mike said:... I live in Costa Rica so it's incredibly difficult to find car yards with or spare parts ...
...The same thing here.
On 4/4/2023 at 2:52 PM, 1 Lucky Texan said:paging @Loyale 2.7 Turbo , he is in Honduras but may have a suggestion.
Yes, you can see how I drive my Subaru "BumbleBeast"
with a Redrilled 114.3 Pattern, since the 1990's Decade:
Kind Regards.
- 1
And everything worked fine, thanks to God:
- 3
Changed all eight old worn Hydraulic Lifters with a set of brand New ones, with their oil filler holes already aggrandized. Changed the old worn valve covers' Seals. Changed both Timing Belts.
Changed the worn old Pilot Bearing from the Clutch...
...completely and thoroughly deep Cleansed the Engine Bay and Painted it:
- 1
Once the Lifters were Ready, I had to ask to a local friend who has a small repair shop,
his kind help and letting me to pull the engine in its place with his tools...
- 2
My "BumbleBeast" it has being running with Valvoline's "MaxLife" semi sinthetyc multigrade oils; however it ran on mineral multigrade oils in the past and after all these years and miles, I decided to change the Hydraulic Lifters with a fresh set of new ones with their tiny holes already Drilled in order to improve the oil flow to them.
The back from a 5/64" drill bit, fits perfect on the tiny holes, but its cutting knives on its other side are wider up to the next size of it, you'll never know how many of these bits I wasted until I found a suitable one that could drill their metal, it is amazingly hard and even tungsten carbide drill bits were wasted by the dozen... so, it is better idea to get the Hydraulic Lifters to a professional lathe shop and let them do that aggrandizement for you, if you can... in my case I done that manually.
Then, a deep cleansing of each Hydraulic Lifter were nessesary.
Eating your Favourite Snack and Soda will help you to be Patient enough...
- 1
I decided to remove the Engine from the Car for three reasons, one was to do a deep Cleansing and repainting all the Engine bay; other reason was to change the Pilot Bearing from the Clutch, as it became loudly Noisy; and finally I decided that it was time to change the old, worn Hydraulic Lifters with a fresh set of new ones... even change the timing belts is easier outside the car, so I did everything at once.
I obtained a set of new Hydraulic Lifters' at eBay:
My beloved Subaru "BumbleBeast" has the oil pump and its Mickey Mouse Shaped seal, in healthy conditions, so the noise that the old, worn Hydraulic lifters were doing, was not the TOD ("tick-of-death") sound; the clockwork noise were coming from their normal wear at this age and mileage...
As I've read several times, long years ago on these Forum; certain members exposed that the oil access holes on the Hydaulic Lifters' body, are so tiny that with age and usage, the varnish and sludge of these engines could restrict and even block the access of the oil at them, making them to work dry and noisy.
Furthermore, experienced mechanics suggested that such small openings on the Hydraulic Lifters' bodies, could be drilled and opened to the next size, in order to minimize clogging and let them get the oil pressure in a better way which may lead to a self cleaning operation.
Here's an example:
On 11/24/2011 at 1:50 PM, Loyale 2.7 Turbo said:
The Timing Belts on my "BumbleBeast" runs Coverless, since year 2009
So, I did a Double challenge, long term experiment with these Coverless Timing Belts, One challenge was mileage lifespan (to reach certain Mileage) and the other challenge was time lifespan (Endurance in time); and the Coverless Belts definitely Surpassed both challenges by far, with flying colors, way better than the covered ones, due to multiple reasons; but someting to consider is that here, in Central America / Honduras, climate tend to be very Stable and Never Snows; however, the belts were exposed to mud, dust, small gravel, small branches and different fluid spills, even an accidental screwdriver dropage during this more than a decade long test / experiment, everything was Repelled by the spinning belts, even they cleansed by themselves, due to their centrifugal action.You can read Further, see photos and discuss the subject, Here:
~► https://www.ultimatesubaru.org/forum/topic/123470-timin-belt-covers/page/3/#elControls_1408538
Kind Regards.
- 1
Pretty interesting... except for the part when you got hurt.
I hope soon you'll be alright and Healthy again.
Kind Regards.
- 1
This is a Nice Project, please share Photos with us as it goes.
Saw the Brat industries website, very interesting...
Kind Regards.
- 2
On 5/18/2022 at 9:01 AM, silverhelme said:
The best option I've seen is to redrill to 4x114. I have a set and as I remember there used to be a thread on how to do it. If I remember Loyale 2.7 turbo said he did it.
Yes ... ...I agree that it is the Best option, 4 X 114.3 ... ...
as the Wheels for that pattern usually has the proper offset for our Subies.
This is what I did it, very Long years ago:
Kind Regards.
On 8/3/2022 at 7:40 AM, 1 Lucky Texan said:
you do way more with a bad knee that I can with 2 good ones.
Thank you for your Kind Words which I really appreciate.
in fact, I just had a surgery on the other Knee too.
_____________________________________________________
Greetings fellows, I have Just a Little Update and a simple Question:
- Update: Thanks to God, this Lifted & slightly modified 2012 Sorento has been Running Flawlessly, we have done hundreds of errands locally and also too many weekend voyages of hours on highways too, with all the family and even our paranormal Dog involved. The engine runs equally on Super gasoline and Regular Gasoline, despite the low quality of the fuels available locally, I guess the GDi computer adjust the fuel / air mixture on the fly...
- Question: as far as I know, the two Timing Chains on this 4 cylinder, GDi 2.4L (G4KJ) "Theta II" engine, are intended to be used during the engine's Lifetime, theres the main timing chain and a smaller one for the oil pump; However, local mechanics has emblazoned the idea of changing them, along their tensioners and related paraphernalia, somewhere around the 100 K or 150 K miles, depending on age and usage. The user manual is not clear regarding the subject.
Any information / experience \ suggestion about this, will be welcome.
Kind Regards. -
15 hours ago, azdave said:
... I'm still rocking the EA82 and enjoying it so far.
Also I'm doing the same, since 1985
However, he has everything to go to the
dark sideEJ route already,So I wish the best luck. EJ engined old subies feels like another car, by the way...
Kind Regards.
- 1
On 12/14/2022 at 3:36 AM, el_freddo said:
Because no one does that!! ...
On 12/14/2022 at 7:56 AM, idosubaru said:Hahahhaa. Lmao Great point !
You've missed this Legendary Thread for sure:
Kind Regards.
I live in the Caribbean area of the World and the Subaru Dealer disappeared years ago, wiyhout aftermarket support, I had to use other brands' car part, and I lifted and improved mine, to the point that the New suspension seems to be Bullet Proof, as the thing runs and has stayed Strong, like new, since years ago... Here you can read my Writeup regarding Suspension improvements, mainly for lifting a little and extra Duty / Load:
Kind Regards.
Miata / Accord coil springs, depend on what you want.
For a little Stiffer Ride, getting rid from saggy butt with loads,
I chose Honda Accord front coil springs on the Rear,
Huge imptovement... I suggest you read the article whose link is on my post above.
Edit: Here it is ~► https://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/
Has further details and photos...
Kind Regards.
- 1
Hi! ... ... How about your Subies?
Talkeetna; the offroad 5 lug 85 wagon.
in Members Rides
Posted
Usually you will never get rid of your Favourite Project car
I'll like to see photos of it.
Kind Regards.
