Everything posted by esh
cv, head gasket and timing belt question
esh replied to esh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cheers for the reply. currently downloading the HTKYSA book. still, anyone know about the CV? I've got an old loyale 4wd with possibly good cv to go on my 94 L series (ea82). -
1) are the CVs on the ea81 and ea82 the same? 2) what do I need for a head gasket change (parts and tools)? 3) and for timing belt change?
[ATTACH]4597[/ATTACH] they are proper 4wd flaring. you can get them by the metter at rubber shops. thes ones without wire insert. I also added another strip of plain rubber to widden the mud flaps cause I like the stock ones
thanks for the link. another question: what kind of t-case is that?Lada? Nissan? and what is the second shifter for?
I did a search and found a lot of bits and pieces but nothing that gave the full picture. thanks
I was trying to find a thread about how to.. T-case and I couldn't find one. can any one explain the principle of that mod and what do you need? I was thinking about 8-12" lift on a brat with a Niva T-case.
http://subaruesh.spaces.live.com/photos/
do you know whos brat is this? this is not a photoshop work http://www.ultimatesubaru.org/photos/showphoto.php?photo=476&si=differential&what=allfields
you can get them on e-bay but I got then from a rubber shop. much cheaper 4 meters for AU$ 47. and I have plenty left. I don't know if you noticed but I used a 60 mm strip of rubber for widening the original mud flaps
after a warning I got from the cops about my off-set I decided I have to put the flares on if I don't want to get a yellow sticker. also trimmed the front fenders. http://subaruesh.spaces.live.com/photos/
a lot of the subaru 4wd in Israel are white simply because they are ex-goverment owned cars.
just use a very big size drill bit. (you might need to use a press drill)
I found this link on the Israeli subaru forum: http://pic.hevre.co.il/UserAlbum.asp?uid=8FFA2CFBEC334369A561A0CAE12395C1&alid=
ya, very soft. you got to have your tyres with low pressure 7-10 otherwise you'll get bogged and in some places it's just like quick send. I"m currently running on re-drilled rims 185/75 road tyres. looking for 15" rims now with minimal positive offset.
took my subi down the beach or actually, took the camera down the beach. I take the subi every second day to the beach but I always forget to take a camera so this time I did. http://subaruesh.spaces.live.com/photos/
cheers mates. i will give it a go
I just re-drilled the mount of the stabilizer rod about 1 cm rear to the original hole. it fitted perfectly.
has anyone had any issues with the speedo cable while doing a 3" lift on ea82? mine was too short and was pulled out of the dash. also, the gear stick wouldn't go in 1, 3 & 5. I had to move the plastic cover of the gear stick few mm forward.
the lift is not byb, it's: http://www.funonwheels.net/hirisesubaru/pages/home.htm the plate should go on top according to the instructions and the block is not turning around. this is how I put it. is there a way to fix the driveshuft or do I have to replace it?
I'm running 3" hi rise lift. cheers guys
I got 6 stud 14" rims that I drilled. I don't know which car they came from but with a 195/75 tyre and 3" lift they rub at the rear of the guard when turning, just where the mud protector is. I'm not sure how to measure offset but I measured 95 mm from the hub to the edge of the rim (on the outside) and they do look like they stick out a bit. what kind of offset do you guys have? is that to much offset? is it worth bitting/cutting and how to? http://subaruesh.spaces.live.com/photos/
sorry, but I'm not sure I know what drive line is. do you mean driveshuft? if you do then no, I didn't disconnect it. and don't under stand why there should be any changes in angles. it's a body lift, it shouldn't change any angles. when I think about it, the angles of the driveshuft do change becuase I used 2" blocks for the driveshuft and the gear, when the rest of the lift is 3". do you think this might be the problem?
