Everything posted by eagleb
Wouldn't that problem be present more frequently? The issue feels like torque bind, with a popping sound, and goes away within a couple minutes of driving. What should I be checking for in the driveshaft ujoints and CVs? Tranny mount seemed like it was in good shape before the install. Thanks for the help.
Well, it shifts better! However, before I start harassing the mechanic again... There is a vibration/shudder when I accelerate slowly from 1k - 1.5k rpm (most noticeable at about 1.25k rpm). The car doesn't stumble, and I can accelerate through it without a problem. Most noticeable when slowly starting from a stoplight/sign. Any thoughts? Also, the car didn't bind at all on on the way home, but did bind a bit this morning. However, the car, and weather, were quite cold, so I won't dwell on it.
It seems as though the clutch pack is the culprit. No at temp light, and the rear diffs match. It could just be a matter of re-breaking in the clutch pack, or swapping rear extension housings with the original trans which was in good enough shape. They said the trans was shifting well, so that's good news. A couple transmissions they had installed previously that were sitting in a yard for some time just needed to be driven 100 miles or so to get the clutch pack back in working order. My fingers are crossed. Thanks again for the help, I'll know tomorrow whether or not I'm going to need to have the rear extension housings swapped.
I'll try to get some more input from the shop before they close this evening. I definitely will not give up on bloobaru. He's finally got leathers, a sweet sound system, and new HGs. After the trans issue is figured out, I'll have an almost brand new car (to me). Thanks for the quick replies, I'll report back asap.
Greetings, Currently, my 96 OBW AT with 122k miles is in the shop. I had them replace my AT with a 98OBW AT with ~70k as my trans had a leak between the front diff and trans, and was having some shifting issues. I am unsure of the vehicle history, the donor car had been sitting uncovered without an engine or front body panels/hood for about a year. Person with the car bought it from the owner who had crashed it in a ditch. Supposedly the front end damage would have been easily repaired, but the owner wanted the 2.5 for his sandrail project. The instrument cluster had been sold on ebay before I got to the car, so I'm trusting that the seller is telling the truth about mileage. Torque converter and driveline were still attached to the trans. Next time I talk to my mechanic, I'll ask if the at temp light is flashing and if they've put a fuse in the fwd holder. Final drive ratios are the same for the 96 and 98 OBWs I took a risk with this trans, as I was unsure of its history. but for $150, I couldn't pass it up. The Problem- Mechanic says the transmission is binding up real bad, evidently it seems worse than just the clutch packs to him (experienced soob mechanic and USMBer). I'm hoping my risk doesn't end up being a money pit. I seem to have bad luck in the drivetrain arena. Any suggestions?
I thought the ratios were the same. Thanks for confirming. If the problem isn't the rear diff (was working fine with the original trans), then what would be causing such serious binding? Clutch packs? Duty C? Could an improperly seated TC cause such binding? Hopefully it'll get figured out soon. I miss my car.
Since I think the transmission compatibility thread is no longer in service... Does the 98 4eat have an external VSS with a single wire coming off of it? I need to be sure all the wiring for the 96 will match the 98 trans. Was the phase II 4eat introduced any earlier than the MY99 Outbacks? Hopefully it wasn't introduced in late MY98.
96 OBW. I won't buy a TCU yet, I just remember from the other post (transmission compatibility) that it might need the matching TCU. There are a few 98 TCU's at a Portland wrecker, so worst case scenario is I pick one up after the install if there's a problem. I'm stoked I found this trans for $150. Almost impossible to find a 70k trans for under $500. The only downside is I don't know the vehicle history. Here's to hoping it all works out
My HG went out at 113k. Nothing in the overflow bottle, just a temperamental temp gage and bubbles in the coolant. It was actually barely noticeable, but I took it in to be sure. Hydrocarbons were detected in the coolant, so I had new HGs installed. If your car has low enough miles, a new head gasket will *most likely* provide you with a solid engine for years and miles to come. If your car is on the higher mileage side, an engine swap may be the best preventative maintenance. How many miles on the car?
