Everything posted by myles
	Like I mentioned in my previous post, the OEM filters from my dealer do not have an ADV. Just to be clear, the anti-drainback valve is merely a neoprene flap that's deflected by oil flow when the engine's running, and falls back into place when there's no oil pressure to keep the oil from draining from the filter. Are you guys talking about the bypass valve, perhaps?
	I only use the 15w50 during the summer months. In the winter, I run Mobil1 10w30. My EJ25 runs terribly on 87-AKI gasoline, even after a Seafoam treatment (removes carbon from the valves and combustion chamber). Tipping the throttle results in much bogging. Remember, the Phase-II EJ25 has a compression ratio of 10:1. Seems a bit high for 87-AKI gasoline.
	You probably don't need to lift the front end to change the oil (I don't lift my '02 Legacy for oil changes). If you do need to raise the front end, place the jack beneath the front crossmember. When raising the rear end, place the jack beneath the differential case.
				Pulling motor
myles replied to swami2806's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Do you want the docs for the '99 pertaining to the heads and rear main seal? Do you know if the 2.5 changed between '98 and '99? -
				Pulling motor
Don't trust Haynes. Spend the US$20 and a bit of time to download the FSM and TSB's (and whatever else you want...you have 72h to download) from techinfo.subaru.com/. I have the FSM for the '99 Leg. Let me know if you want me to email the relevant sections.
