Indeed, the rear bulbs were getting juice (pretty obvious there, eh?)...
Anyway, I found the solution in the "compilation FAQ"...
Yesturday I cleaned the dash..... duh
I believe it's the tail lights... If I press the brake pedal then I get brake lights as usual. Releasing the brake pedal goes back to the tail lights being on. The parking lights in front are not on..
Last night I parked my 90 Legacy and started to walk into the house when I noticed that the tail lights were on. I checked the light switch (on the turn signal arm) and it was off.
I had to unplug both tail lights to shut them off.
Can anyone help me troubleshoot this? Where do I start?
Any help appreciated...
I have no idea if the t-belt jumped timing, but guess I'll have to have a Subaru dealer check that...
I checked the codes because the Check Engine light was on/off/on/off while driving. It can come on with the engine fairly cold and when hot. Doesn't come up as soon as the car is started.
thx
bob
Thx much, both of you... Forgive my ignorance, but what is the difference between "re-setting the ECU" and "clearing the codes"? Isn't that the same thing?
I really appreciate the info on this forum regarding the ECU trouble codes and how to access them. I did exactly as instructed and managed to get 4 error codes from the Check Engine light.
My problem is that I'm not sure which of these problems to address first, and would really appreciate some advice here.
The error codes (from my '90 Legacy) are:
11 Crank angle sensor.
13 Cam angle sensor.
23 Air flow sensor.
35 Canister purge solonoid valve.
** Edit** How do I clear the codes? The same thread/sticky? that gave me the procedure was unclear on how to clear them.
Thx in advance for any/all advice.
bob
