				Posts1779
				Days Won1
Everything posted by frag
	  Hypermilingfrag replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX There was a long discussion in january (in which I was a participant) around a similar problem. Here are two links: http://www.ultimatesubaru.org/forum/showthread.php?t=82266&highlight=compression+braking and http://www.ultimatesubaru.org/forum/showthread.php?t=83815&highlight=compression+braking
	Remove the hose going to the pcv and push some pigtails aside. A medium lengt extension with the proper size socket will get it out. I think I used long nosed pliers to remove the connector first. There will be a small amount of coolant seeping out. You can lower the coolant level in the rad by a couple of inches to prevent that.
	Just bought a pair of Thule bars for my 96 Leg Brighton Wagon (bare top, no preinstalled rails). Want to transport a medium length kayak (11 feet). The specifications are to position the front bar 33 inches from the top of the windshield and to put the rear one 28 to 31 inches from the front one. I find that the bars are too far back and too close to each other. The seller, a Thule and Yakima specialist insists that I should follow the specifications for my car. What would be the problem of putting the bars more to the front and farther apart? Anyone has a Legacy with Thule bars? How did you install them?
	It all depends. Lots and lots of years ago the trans on my front wheel drive Austin 1800 stuck in fourth. It took me one full week and the help of the shop manual to open the trans and find the problem. I had almost no experience doing mechanics and I repaired it successfully. Maybe I was lucky. If you're patient and have lots of time, maybe you can repair it. If it's not external of course. I dont remember the exact details, but the problem was a bulged washer (?) (2 or 3 inches across) at the end of one of the shafts. I had a new one machined and replaced it.
	  Hypermilingfrag replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX I do pretty much the same thing when it's possible. Next step is a sail.
	  91' Loyale Stuck in 4wd...HELP!!!frag replied to scoooobie_du88's topic in Old Gen.: 80's GL/DL/XT/Loyales... Try it on the old gen Board. Lots of actual Loyale owners there. I had one 8 years ago and it was stuck in 4WD cause a friend had driven it on pavement with the 4WD engaged. Your prob is probably different. Good luck!
	  91' Loyale Stuck in 4wd...HELP!!!frag replied to scoooobie_du88's topic in Old Gen.: 80's GL/DL/XT/Loyales... Happened to me. Did nothing special except alternating a few times between first and reverse and turning the steering wheel to the right and to the left a little and pushing and releasing the button constantly during that time. The transfer case is jammed and you have to «shake» it a little to free it. The best I can offer...
	  Disable AWD?frag replied to TIMINTEXAS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Maybe bearing and gear friction could also be taken into account ? Less weight, but also less friction.
	Haynes: Temp in °F Resistance (ohms) 212 ----------176 194 ----------240 176 ----------332 158 ----------458 140 ----------668 112 ----------972 122 ----------1182 104 ----------1458 95 -----------1800 86 -----------2238 76 -----------2795 68 -----------3520 58 -----------4450 50 -----------5670 40 -----------7280 32 -----------9420
